20 Most Recent Sony CDXGT740UI InDash MP3WMAAAC Player Questions & Answers
common issue with the sony models your usb port is bad. easy fix is auxilary cable input in the front from ipod or back in the unit but cheapest is a 10 dollar adapter for fm / blu tooth streaming. theres your solution thumb me up sorry bad news bout the usb
Sony CDXGT740UI... | Answered on Mar 25, 2011
if you have a multimeter, make sure the yellow is connected to a constant power source. turn your key to the off position and see if the yellow wire still has 12 volts going to it.
Sony CDXGT740UI... | Answered on Feb 01, 2011
Request the wiring diagram directly from Sony.
Sony Car Audio &... | Answered on Oct 28, 2019
GO INTO THE MENU AND FIND THE AUDIO CONTROL FEATURE AND AND DO THE ADDJUSTMENT
Sony Car Audio &... | Answered on Oct 07, 2019
Left Front (+) White Left Front (-) White/Black Right Front (+) Grey Right Front (-) Grey/Black Left Rear (+) Green Left Rear (-) Green/Black Right Rear (+) Violet Right Rear (-) Violet/Black
Sony Car Audio &... | Answered on Jun 09, 2019
No longer listed for sale as it is old. $40 used.
https://picclick.com/Sony-Marine-Stereo-Cd-Receiver-Deck-Cdx-M501P-183497958733.html
look at Jenson Marine instead. I have one on a Boston Whaler.
https://www.jensenmarinedirect.com/
Sony Car Audio &... | Answered on May 12, 2019
+ to battery, - to ground metal in the car location where you're installing and rem to blue on back of radio.
Sony Car Audio &... | Answered on Apr 16, 2019
I'm pretty sure it means that you have to much mucis downloaded
Sony Car Audio &... | Answered on Apr 04, 2019
If it ain't turn on at all check your fuse box. It could he a fuse under hood in car under dash. If the fuse is good then pull the radio out. Do a smell test on it. If you don't smell anything suspicous then check your red yellow and ground wire. Yellow being your switched 12v which turns off and on with ignition. Check red wire also. Also ground wire is very important.if none of those work it will need to be replaced. Check fuses carefully. A blown fuse can sometimes be easily missed
Sony Car Audio &... | Answered on Apr 02, 2019
Hi nick, there can be many causes for this fault.
1. your speakers or speaker cables are faulty, then this problem will come up.
2. your installation is done incorrectly, or with the wrong gauge of power cables can cause this problem.
3. your vehicle battery could be weak.
4. you could have an internal problem with the amp only, which needs repairs.
cheers.
Sony Car Audio &... | Answered on Mar 09, 2019
Sony CDXGT740UI InDash MP3WMAAAC Player Logo
4 questions posted
Top Sony Car Audio & Video Experts
Larry Stiles
Larry Stiles
Dalynn Turner
Marvin
Marvin
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Car Audio & Video
Most Popular Question
installed sony
  • Car Audio & Video
