20 Most Recent
FUJIFILM Instax 210 Film Camera Questions & Answers
I loaded my fujifilm instax backwards? how do I get the film out
I figured it out! I shoved my film pack in backwards when I was in a hurry. The top part (where the yellow mark should be) was sticking out slightly, so I figured I'd try prying that part out first...while I was doing that I noticed the bottom of the pack was slightly loose. So I stuck something between the plastic frame of the film pack and the film itself (I figured I'd sacrifice the pack rather than the camera) and the whole pack popped out pretty easily!! Hope this works for the rest of you!
I have a Fuji Instax
The same thing happened to me. Make sure that the mechanism arm on the inside that pushes the picture up is connected with the metal piece on the right hand side. The two can come loose allowing the metal piece to not bring the arm with it when you take a picture. Also the roller could have fallen down a bit. From the inside, press the roller up (it will click when it is in the right spot). The roller should be even all the way across and pushed all the way to the top of the camera.
I hope this helps if you haven't been able to fix it already.
(When all else fails, try changing the batteries.)
Stuck lens
Hi, 210 wide camera lens stuck is cause the spoil gear. This is commonly happen to physical damage camera.
On every shot i take
you could just cover the flash with some black electrical tape, that's the simple answer, and reversible :)
