20 Most Recent Mitsubishi SL4SU ColorView Multimedia Projector Questions & Answers
Zoom focus
It has a magnify feature on the remote I think. You can reset the machine by holding down power computer and video buttons for a long time.
11/26/2013 4:56:54 PM • Mitsubishi SL4SU... • Answered on Nov 26, 2013
2answers
Blinking Light on Mitsubishi SL4SU Projector
To jmatthews
Both power light and status light a solid red with no response to any buttons indicates the bulb timer has expired. You need to reset the timer by pressing and holding the left arrow key, the right arrow key and the power button all at the same time for a few seconds.
If there are no problems, the projector will fire up, but you must replace the bulb as it will fail soon and perhaps explode when it does.
Take care
10/3/2013 5:19:58 PM • Mitsubishi SL4SU... • Answered on Oct 03, 2013
2answers
Yellow spot
the problem is in the light path starting with the blue input polarizer then the blue lcd hopefully its just the input polarizer. worst case you will have to replace the LCD block witch is expensive to do. the polarizer ia a speacialy tinted glass designed to help with the LCD's temp.
3/13/2013 7:55:52 PM • Mitsubishi SL4SU... • Answered on Mar 13, 2013
Mitsubshi sl4su
THis is a very short throw even for a "short throw" lens. I would verify that this is the proper lens by its numbers and verify what you should be seeing by its tech specs (focal distance./image size to be expected)
1/10/2013 2:11:03 AM • Mitsubishi SL4SU... • Answered on Jan 10, 2013
Mitsubishi SL4SU
what is the status and power doing because there is no information here
12/9/2012 10:47:59 AM • Mitsubishi SL4SU... • Answered on Dec 09, 2012
No image is projected.
go through the sources, Computer,Video,Svideo
12/9/2012 10:37:46 AM • Mitsubishi SL4SU... • Answered on Dec 09, 2012
I have a Mitsubishi sl4su projector that I use for
s video doesn't carry sound so you will have to use phono plugs too
12/8/2012 12:40:05 PM • Mitsubishi SL4SU... • Answered on Dec 08, 2012
2answers
When trying to watch a film off the computer through the projector the colour red comes out green on the projector.
check your cable and use a different laptop or desktop to eliminate the projector. always do a factory reset.
11/21/2011 7:11:44 AM • Mitsubishi SL4SU... • Answered on Nov 21, 2011
I have the SL4SU projector.
press menu then move to signal and the shutter options are there
11/21/2011 7:10:15 AM • Mitsubishi SL4SU... • Answered on Nov 21, 2011
2answers
How to reset the bulb life to 0 on a sl4su it
hi,
Do the following for reset the lamp hour to zero.
Reset the timer by pressing and holding the left arrow key, the right arrow key and the power button all at the same time for 5 seconds.
OK
9/25/2011 1:15:57 PM • Mitsubishi SL4SU... • Answered on Sep 25, 2011
My SL4SU projector will not
ok make sure its nt to close or far away and the focus ring should be in the midle to find out how to get a good focus hook up a laptop and search google for projector focus chart and use that and blam should be focused
9/21/2011 10:37:22 AM • Mitsubishi SL4SU... • Answered on Sep 21, 2011
2 red lights on projector.
Reset the Bulb life. Every time bulb changed need to reset it to bring it back to 0 hour.
9/21/2011 10:33:01 AM • Mitsubishi SL4SU... • Answered on Sep 21, 2011
HOW DO I CHECK LAMP LIFE FOR MITSUBISHI SL4SU
If you go into the menu of the projector.
Find the lamp status or info command.
It will tell you the current information.
Please dont forget to vote this answer was helpful and accept my answer.
Many thanks
2/20/2011 9:48:08 AM • Mitsubishi SL4SU... • Answered on Feb 20, 2011
Sl4u Projector
It could be that one of the fans has broken you will be able to hear them because there are 5 in there. if you are under warantee send it back if you are technically minded take it apart and watch which fan doesnt start then order from mits or from a local supplier,.
1/2/2009 1:39:09 PM • Mitsubishi SL4SU... • Answered on Jan 02, 2009
Problem with mitsubishi sl4u projector
make your pc or laptop start first and then the projector.
3/18/2008 3:50:13 PM • Mitsubishi SL4SU... • Answered on Mar 18, 2008
2answers
Mitsubishi P93 thermal printer. How do I fix gear lock error on it please?
This is a highly specialized piece of equipment used for printing ultrasound and medical images. Limited help in this link https://www.google.com/search?q=mitsubishi+p93+thermal+printer+gear+lock+error ..
4/25/2024 1:41:23 PM • Mitsubishi... • Answered 4 hours ago
Mitsubishi CP9550DW-S Photo Kiosk error: "(the ink ribbon is not standard)"
This suggests it is a driver issue. My first thought is that your supplier has provided copies, not originals.https://www.google.com/search?q=Mitsubishi+cp9550dw-s+the+ink+ribbon+is+not+standardIt is very specialized though and not a machine used here in North America. Contact Mitsubishi Support direct...
9/12/2023 6:28:46 PM • Mitsubishi... • Answered on Sep 12, 2023
I have a Mitsubishi XD206U DLP projector. When it receives a 720p or 1080i signal The image has extreme green tint. I adjusted in the settings w no progress on fixing this. Any thoughts?
HELLO Holly ensure that the cables connecting your video source to the projector are securely plugged in and not damage .Also test the projector with different input source it trully assist you to identify if the issue is with the projector or the specific input source.
8/19/2023 5:01:30 PM • Mitsubishi... • Answered on Aug 19, 2023
HC3800 Mitsubishi color wheel model or part number?
The Mitsubishi HC3800 projector uses a color wheel with the model number VLT-HC3800LP. This is the original color wheel that is designed specifically for the HC3800 projector, and it should be able to replace the existing color wheel in your projector. It is important to use the correct color wheel for your projector to ensure optimal performance and avoid any damage to the projector. You can purchase the VLT-HC3800LP color wheel from Mitsubishi authorized resellers or from the Mitsubishi website. You can also check for other electronic resellers or online marketplaces for availability and pricing. I recommend you to confirm with the seller that the part is compatible with your specific projector model and serial number, before making the purchase. It's also important to mention that, replacing the color wheel should solve the noise issue you're experiencing. But, it's always recommended to check the projector warranty status, or if the projector is out of warranty, consult with a professional technician before attempting to replace any part of the projector.
1/18/2023 9:28:38 AM • Mitsubishi... • Answered on Jan 18, 2023
Mitsubishi SL4SU ColorView Multimedia Projector Logo
24 questions posted
Top Mitsubishi Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Office Equipment & Supplies
Most Popular Question
yellow spot
  • Office Equipment & Supplies
