20 Most Recent
Rokinon 500mm f63 Mirror Lens for Nikon Mount Questions & Answers
Fungus on Rokinon 500mm mirror lens
Do you have a lens collimator and other equipment necessary to ensure proper alignment when reassembling the lens? If not, take it to a good camera shop and have a properly trained and equipped professional do the job.
Error 99 on Canon EOS350D
Cannon does not say what error codes above code 02 mean. They only suggest the costumer to make contact with the nearest Canon service centre.
But connecting a non autofocus lens from an other brand, could be something the camera can't cope with. And the most Canon (and other brand) camera's can't focus when a lens has a aperture greater than f/1: 5,6. The f/1: 6,3 or perhaps even f/1: 8 is one or two stops to much for your camera. Special when you try to use this lens in no bright places.
Error 99 on Canon EOS 350D
Are you trying to waste people's time here, or what?
Rokinon lens, Nikon mount, then mixing that with a Canon EOS 350D???
Fungus inside Rokinon F6.3 mirror 500mm lens
This will have to be sent in for repair, no other way around it. Call a camera repair facility first before you send it in to get a quote, many times a new or used lens is cheeper. Don't forget to check Ebay. Good-luck
Hi there
I just came across my old camera K1000
Lenses with the Pentax K mount, such as those used by the K1000, will fit onto current Pentax digital cameras, with some restrictions. For more details see
http://support.pentaximaging.com/node/3
Bascially the t-mount was screwed
The Rokinon lens lacks the electronics to communicate with the camera. You need to set the camera to the Manual exposure mode. Since the mirror lens also lacks an aperture control, you will need to control the exposure by changing the shutter speed and/or the ISO setting. Also, depending on the model of your Nikon, you may or may not get any exposure assistance from the camera's light meter. If you don't, you can use the image review on the LCD and the histogram to tune your exposure.
How to attach filters to a Rokinon 500mm/ 1000mm
For the Rokinon 500mm F/6.3 lens, you can either attach 95mm filters to the front or 34mm filters to the rear of the lens.
For the Rokinon 500mm F/8 lens, you can only attach 30.5mm filters to the rear of the lens.
To attach a filter to the rear of the lens, remove the lens from the camera (or take the rear lens cap off). There's a threaded screw mount just inside of where the lens fits onto the camera. Take your filter and screw it into place. Hand tighten until it's snug and doesn't project in the way---remember, you're going to want to take it off again later.
TRYING TO CONNECT
Fixya does not provide any kind of internet connectivity - methinks thou mayst have directed thy query to the wrong site.
Rokinon D=70mm F=500mm user manual
You can download a manual for almost any equipment by Googling the make and model followed by the word Manual, then follow the appropriate link(s).
Roku2 universal code
From Internet, check it whether it works for you.
52371 and 53061 are the two codes listed for Roku for the RCRN04GR remote. The 53061 code worked with full functionality for my Roku 3.
How do you get out of Roku back to regular tv?
Change the Input on the TV. Like from HDMI 1 to HDMI 2 for example. Or to component video. Trace the wire from your cable /satellite receiver and see where it's plugged into the TV then select that input.
Why doesn't my rokinon 500mm lens work with my Nikn D3100 camera?
The lens does not have the electronics to communicate with the camera. It will work fine in Manual exposure mode. Turn the mode dial to M. You'll have to set the shutter speed yourself, without any help from the camera's exposure meter. You'll also have to focus yourself, of course.
