20 Most Recent Panasonic FH20 Digital Camera Questions & Answers
I can't download my photos to my pc. my usb
Now if there is any camera that was earlier loaded and the program is already registered, it is better to remove or uninstall by opening programs and uninstall.
If the camera is not detected then you can remove the SD card and use it on the PC ( use a card reader if needed) Now the images can be loaded straight into the PC by copying from the memory.
8/3/2011 2:13:08 AM • Panasonic FH20... • Answered on Aug 03, 2011
I get a zoom error
Checkout this tip about digital camera error messages
Lens Errorfix for Digital Camera
heatman101
5/19/2011 8:42:42 PM • Panasonic FH20... • Answered on May 19, 2011
Photo fun studio downloaded my first group of
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
5/18/2011 5:04:15 PM • Panasonic FH20... • Answered on May 18, 2011
Small dark spot on right side of screen/lens, also
Not a good sign I'm afraid to say. If the 'dark spot' is coming through into the pictures that means some pixels are not sensing light. They will look square shaped if you expand the picture on your PC.
If the lCD was faulty (or had some dead spots) this would show when focussing and taking pictures, but, would not show in the final picture.
I'm assuming you have cleaned the lens (just in case) there is a 'dirt' spot that a finger could have put there. (clean with damp soft tissue )
There is a Panasonic help site which I checked but most reported problems were USB connections and battery life etc .. Try it and ask anyway - can always ask -- Ray
http://www.retrevo.com/support/Panasonic-DMC-FH20-Digital-Cameras-manual/id/23641dj090/t/2/
1/19/2011 3:29:55 AM • Panasonic FH20... • Answered on Jan 19, 2011
How do I download photos
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
12/12/2010 1:11:57 AM • Panasonic FH20... • Answered on Dec 12, 2010
2answers
I have a panasonic Lumix camera and it keeps
Hello and Welcome to FixYa!
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.
You can see the snap attached below;
If the lock switch is not on lock;
  • Slide the switch up and down. Repeat this 3 times.
  • Let it stay on the Lock position for 30 seconds.
  • Slide the switch up to unlock the card.
  • Try to transfer files into the device.
If none of the above works, then you card in either damaged (Format it) or is Password protected.
If you think I was of help, your token of appreciation in the form of rating and a testimonial will be esteemed.
Concerned, Nooh
11/28/2023 7:18:52 PM • Panasonic... • Answered on Nov 28, 2023
2answers
How to change language for Panasonic tz110 camera
https://www.panasonic.com/content/dam/Panasonic/support_manual/Digital_Still_Camera/English/TZ80_and_TZ110_Basic_Operating_Instructions.pdf
3/28/2023 1:59:38 PM • Panasonic... • Answered on Mar 28, 2023
I want to change language from Japanese to English Panasonic CN H500D
To change the language on your Panasonic CN-H500D, press the "Menu" button on the remote control. Use the arrow keys to select the "Setup" option, then press the "Enter" button. Select the "Language" option, then press the "Enter" button. Use the arrow keys to select the language you want to use, then press the "Enter" button. The language will now be changed to the one you selected.
2/21/2023 10:01:11 PM • Panasonic... • Answered on Feb 21, 2023
2answers
My panasonic vdr150 pc mode not working
It sounds like you are having trouble using your Panasonic VDR-D150 camera in PC mode. Here are a few things you can try to troubleshoot the issue:
Make sure that the camera is properly connected to your computer via the USB cable.
Check that the camera is turned on and in PC mode.
Check that your computer recognizes the camera as a device. You can do this by going to the "Device Manager" in the Control Panel and seeing if the camera is listed under "Imaging devices."
If the camera is not listed in the Device Manager, try unplugging and re-plugging the USB cable and restarting your computer.
If the camera is still not recognized by your computer, try using a different USB cable or a different USB port on your computer.
If none of these steps help, it is possible that there is a problem with the camera itself. In this case, you may need to contact Panasonic for further assistance.
12/24/2022 10:12:47 PM • Panasonic... • Answered on Dec 24, 2022
I need charger for Panasonic ER2031K model beard hair trimmer
We do not sell anything here, try eBay.
11/22/2022 4:59:51 PM • Panasonic... • Answered on Nov 22, 2022
My Lumix dmc fz4 turns on and says memory card
Camera only supports Standard SD cards up to 2GB. I would go from there.
9/30/2022 12:11:49 AM • Panasonic... • Answered on Sep 30, 2022
I have a Panasonic Lumix DMC L580 and it states that the memory is full. As i dont have a manual how do i delete what is held in the memory please cheers
Are you sure of the model number? I can't find anything about a Lumix DMC-L580. There is a Lumix DMC-LS80. Make sure that you save any pictures before deleting them. Also make sure to have fresh batteries or the camera connected to AC power. If the camera runs out of power, the process will not complete. To delete pictures from the internal memory, slide the recording/playback switch down. (The switch to the upper left of the arrow keys on the back.) This puts the camera in Play Back Mode. Use the Up/Down arrows (if needed) to select normal playback mode and press Menu/Set (in the center of the arrow keys). The delete button is the one on the right side below the arrow keys. Use the left/right buttons to select a single picture. Press delete. Press the left arrow to highlight Yes. Then press Menu/Set to confirm deleting the image. To delete multiple pictures, use the down arrow to get to Multi Delete or All Delete (instead of the left arrow). Press Menu/Set. For All Delete, you may see an option to choose All Delete or All Delete except (star). The star indicates Favorites. If needed, pick one, press Menu/Set. Use the left arrow to select Yes and press Menu/Set again. For Multi delete, use the left and right arrows to navigate through the stored pictures. Press the down arrow to select an image to delete. When you have marked all of the pictures that you want to delete, press Delete again. Press the up arrow to select Yes and press Menu/Set to initiate deleting these pictures. (Note: if a picture is protected, pressing the down arrow will result in On icon blinking red.) The manual for DMC-LS80 is available from Panasonic support here: https://www.panasonic.com/au/support/manual-download/imaging/lumix-cameras/dmc-ls80.html . The current link to the manual is https://www.panasonic.com/content/dam/Panasonic/support_manual/Digital_Still_Camera/English_02-vqt3-vqt9_other/DMC-LS80%20Operating%20Instructions.pdf . See page 20 for the section on selecting the mode. See page 35 for deleting pictures. I hope this helps. Cindy Wells (if you have a memory card in the camera, you will need to do the delete steps in two steps. Delete all (or multi) pictures from the internal memory and the memory card separately.)
7/7/2022 6:22:48 PM • Panasonic... • Answered on Jul 07, 2022
Panasonic FH20 Digital Camera Logo
Popular Tags
7 questions posted
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
View Most Popular
Panasonic Cameras
  • Panasonic Cameras
Most Popular Question
39 t download photos pc usb
  • Cameras
