20 Most Recent
FUJIFILM FinePix S1800 Digital Camera Questions & Answers
Purple line through pictures taken with Fujifilm Finepix s1800
Hello. Unless you have an issue with the lens (crack or deep scratch) it sounds like an issue with the CCD. The CCD captures the image from the lens and digitizes it. There's also a chance it could be some other part of the electronics but I would bet on the CCD. You could try a factory reset but I really doubt it will help. I'm sorry about your camera.
Lens will not open
You have a problem with your lens, maybe a decentered lens. Make sure there are no obstructions in the way of the lens. It may need to be serviced.
Fujifilm finepix s2750hd
Amazing, I had exactly the same problem an finally resolved it by a good old fashioned thump on the palm of my hand! Thanks Ty Price!
Camera won't turn on
Be sure they are NOT rechargeable type, and do not use dollar store low end batteries
Suddenly can't transferphotosto computer
Try NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as
Picasa.
Cant see photos
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
