20 Most Recent Panasonic Lumix DMC F3 Digital Camera Questions & Answers
Make sure you are not using an incompatible card like a SDHC card which looks identical. If the F3 can use those cards, make sure you format it in the menu system. If it still fails, try another card, it may be bad. Remove the card and do a short recording to internal memory to check system, if it is capable.
Panasonic Lumix... | Answered on Sep 19, 2019
Do you really need a driver?
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Panasonic Lumix... | Answered on Nov 22, 2018
It's likely that the spot is a speck of dust that has found its way inside the camera and onto the sensor. Apparently when the lens barrel extends after the camera is turned on a small amount of suction is generated - enough to pull tiny specks of debris inside. Please refer to the following video:
https://www.youtube.com/watch?v=0nmwt0frZns
Panasonic Lumix... | Answered on Apr 17, 2018
Unfortunately, replacement will probably be the only solution - any liquid, especially something sweet and sticky like orange juice, is likely to ruin electronics. Can you claim on your insurance ?
Panasonic Lumix... | Answered on Sep 24, 2016
I think it must be a fault with the camera as we brought one for my daughter for christmas and had the same problem.we exchanged it and it was ok for a couple of weeks but the black mark has appeared on this one now so we are returning it and asking for a refund.
Panasonic Lumix... | Answered on Apr 11, 2014
You really can't. You can copy images on your computer to an SD Card and then insert the SD Card back into the camera. But, doing this after editing could mean that you will not be able to see those images on the camera anyway.
Panasonic Lumix... | Answered on Oct 24, 2013
Same for me, I am not able to save picture.. hw to fix it
Panasonic Lumix... | Answered on Aug 15, 2013
It doesn't matter to the camera what operating system you have on your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Panasonic Lumix... | Answered on Oct 03, 2012
Try NOT connecting your camera to your computer.
Go to Menu find Adjust ISO settings in camera it may be on Auto or at low setting . The Higher the setting in ISO the lighter the picture this is commonly used in low light settings.Play with it until desired ISo works for you . Nice camera nice lens !
Panasonic Lumix... | Answered on Sep 20, 2012
This is a faulty or damaged LCD screen. The fact that the pattern of dots and lines is unchanged by zooming and appears on the menu screen confirms it.
The LCD cannot be repaired, it must be replaced. As long as the fault is not due to misuse (such as being impacted or dropped or getting the camera wet) then the damage is covered by the manufacturer's warranty. Contact Panasonic in your country to arrange a free warranty repair; they will normally require proof of purchase and will check the camera to look for evidence of misuse when they receive your camera. If they find any then the repair becomes chargeable.
I hope that my speedy and free reply has been of use to you; please take a moment to rate my answer.
Panasonic Lumix... | Answered on Sep 14, 2012
Consider NOT connecting your camera to your computer.
Panasonic Lumix... | Answered on Jul 08, 2012
uh Charge it? lol
open mmc & connect with card reader to laptop.or" use data cable.
Panasonic Lumix... | Answered on May 30, 2012
For most cameras, this is not only not possible but, even trying it can cause problems with your camera.If your pictures are being automatically deleted after downloading, it's usually because the program you use for downloading is set to do that. If you don't like that feature, you will need to go into the settings area and change it. Or, you could just download to a folder you create on your desktop. That way, your pics are still on your memory card and you can now send the pics in the folder to any program you like.
Panasonic Lumix... | Answered on Oct 24, 2011
Panasonic Lumix DMC F3 Digital Camera Logo
76 questions posted
Top Panasonic Cameras Experts
Ekse
rajiv6089
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
View Most Popular
Lumix Panasonic
  • Lumix Panasonic
Most Popular Question
pictures all dark even flash
  • Cameras
