20 Most Recent
Canon RC6 Wireless Remote RC 6 Questions & Answers
How do u use the
don't set for 2 sec, set the camera to 10 sec self timer and click the remote, should work instantly with every click. just remember to set for regular shooting if not using the remote. can be very annoying to wait 10 sec for a shot, unless you want to be in one?
12/15/2016 9:29:26 AM •
Canon RC6...
Answered
on Dec 15, 2016
I've Cannon 1100D and I
Hi! Unfortunately,the remote controler RC-6 isn't compatible to your 1100D. Because this Canon model doesn't come with the options for remote control, but you can use the Rs-60e3 wich is a cable remote.Hope it helped!
4/28/2013 9:21:23 PM •
Canon RC6...
Answered
on Apr 28, 2013
I just bought a canon
It is compatible, but you have to delve into the camera menu to activate the function. I can't give you specific instructions as to how to do as the browser on my phone can't read .pdf documents.
If my answer is sufficient to have solved your problem then please let me know by rating my answer. If not and you require specific menu guidance then please add a comment and I shall provide a more comprehensive answer as soon as I am able to do so.
2/25/2013 3:15:51 PM •
Canon RC6...
Answered
on Feb 25, 2013
Looking for directions on using
Press the [AF-DRIVE] button and select the self-timer mode. Point the remote controller toward the camera and press the button.
Full details are in the "Remote Control Shooting" section of the camera manual (page 102 in my copy). If you need a manual, you can download one at
http://gdlp01.c-wss.com/gds/0/0300004270/01/eos5dmkii-im4-en.pdf
7/20/2011 11:03:14 PM •
Canon RC6...
Answered
on Jul 20, 2011
Canon 12x36 is ii stabilization is not working properly. Stabilization
tends to want to stray.
Hello, I think dust, smudges, or fingerprints on the lenses can affect image quality and stabilization performance. Use a soft, lint-free cloth or lens cleaning solution to gently clean the lenses of your binoculars. Make sure not to apply excessive pressure or use abrasive materials that could scratch the lens surface. Moreover, when using image-stabilized binoculars, it's important to hold them steadily and avoid sudden movements. Rest your elbows on a stable surface or use a tripod if possible to minimize hand tremors. Ensure that you're using proper stabilization techniques to maximize the effectiveness of the stabilization feature.
Canon Digital IXUS 500 5.0MP is not powering on when CF card inserted.
In general Compact Flash Cards have to be formatted within the camera that is using them as they use a format proprietary to that camera. Also there are size limits on cards. If your camera will only take 16 Mb cards and you put a 32 Mb card in, it will not read it. It sees it as 'No Card Present'.
I think the other answer is an AI Answer Bot.
I have a Canon IXY digital 930 IS camera and its FUNC.SET. button(aka ok button) is not working and i want to reset the camera because all functions aren't working properly.so how to reset the camera.
To reset your Canon IXY Digital 930 IS camera, you can follow these steps:
- Turn off the camera: Make sure the camera is powered off.
- Locate the menu button: On the back of the camera, you should see a button labeled "MENU." This is typically used to access the camera's menu settings.
- Press and hold the menu button: With the camera powered off, press and hold the MENU button for a few seconds.
- Power on the camera: While still holding the MENU button, press the power button to turn on the camera. Continue holding the MENU button until you see the camera's menu screen.
- Reset the camera: Once the menu screen appears, navigate through the menu options using the arrow buttons on the camera. Look for a "Reset" or "Factory Reset" option. The specific location and wording may vary depending on the camera model. Select this option to initiate the reset process.
- Confirm the reset: The camera will likely prompt you to confirm the reset action. Follow the on-screen instructions to confirm and proceed with the reset.
- Wait for the reset: The camera will perform the reset process, which may take a few moments. Once the reset is complete, the camera settings should be restored to their default values.
