20 Most Recent
Charter Cable Time Warner Cable Box Universal 5-Device Remote Control Atlas 1056B01 Black Questions & Answers
How do I link my blackweb sound bar model BWC18SB001 to my Charter cable remote?
Hey Sarah..
My sound bar automatically connected with the charter remote when I connected the sound bar to the TV with the optical cable.. it cuts the TV (LG) and the sound bar off/on using the charter remote. Sometimes it gets out of sync and I have to use the sound bar remote to cut it on/off.. only once and it starts working again.
My replacement rc-518m remote control is stuck in TV mode how do I get back to a/v
It may be necessary to take the remote apart and clean the contacts with rubbing alcohol and a tissue on the board that is inside. If that doesn't fix it, a replacement is necessary at Ebay.com https://www.ebay.com/itm/394877786274?itmmeta=01HT47X6X7WE749Y2CMG3NX54S&hash=item5bf08cd8a2:g:7pQAAOSwn7BlAn8h&itmprp=enc%3AAQAJAAAA4OMK5%2BdFWZwJQhIS5nEQ3eO7C2zq5QRICeu%2BbPKwqrfkc8con3byi0%2BbabcDYrBTOEyKclvkbzHrOJ1lVMfwduYTPcx0fAcW5XmaZ3ZRWS1%2FnVxMUIwno%2BPNUVuNqN%2FCSDJJ3gG2hQ%2BbGGyfUiO2ppgtjsvtiihnrClntKtSssM8RikHgpG8y9SjAz6z0V0GPkVJf6gypymGRdzz4HfuNn%2BkiMmAXp2NHVWpP6xfbghej%2B1MkOgqhJxV4V1B%2Bp8wVx%2BKV36M%2FVEdzoejZajCMt9ApRe1beW4a0rCXTdGZRuV%7Ctkp%3ABFBM2u70h9Fj
I Have Lost My Remote To My Studio Standard RS-912
If you have switched off it by using power button to its remote control, you must have its remote control to switch it back on. Anyway, try pressing the Ch up or Vol up buttons once. In rare cases, this might make it switch back on.
I need a replacement remote control for JVC NX-BD3 network media system
If you wish to get setup codes, three
digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to
some popular model remote controls are given. Select the 'Timeslide'
option from the drop-down list by the 'Sidebar' at the display
window. It will make search easy.
What is the universal remote
To setup so a firestick could control my Mastertech tv when I tried element from the brands to choose from it worked like a charm for on/off control, volume and mute controls from the firestick. So you might try using Element as a brand or the codes for Element tv's. BTW, I went through several brands before I landed on Element which worked.
Program codes for symphonic dvd player
Hi David, indicate the brand and model of the team you are commenting on, in order to find the best possible solution
I wait your answer
Regards Franco Dosil
Hola David, indica marca y modelo del equipo que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Saludos Franco Dosil
Tcl power comes on but no picture or sound. Tv has backlight lights when powered on
Hello ! It sounds like you are experiencing some issues with your TCL TV. It's great that the backlight lights are working fine. The blinking *********** light and white screen definitely indicate a problem.
One possible issue could be with the internal circuitry or the display panel itself. It's best to contact TCL support or a professional technician to diagnose and fix the problem. In the meantime, you can try power cycling the TV by unplugging it for a few minutes and then plugging it back in.
As for uploading a video, you can try connecting your device to a computer and transferring the video file that way. Alternatively, you can upload the video to a platform like YouTube and share the link for others to view. I hope this helps!
