20 Most Recent
ASUS Eee PC 1001P Netbook Questions & Answers
Wont turn on or charge
1.Remove battery and also disconnect the adaptor and press for 30 sec for cmos cell to clear.
2.Connect adaptor and press power on switch
3. if still there is no sign of display on screen then you need to visit nearest service centre.
Touchpad
Update your latest driver to resolve this problem ...Good Luck
No disc
You can remove or change the Window's User oradministrator's password. You need access to a computer with Internet access todownload the Hiren's Boot CD and burn it onto a CD.Then insert this CD into the laptop/computer and boot upthe laptop/computer with the Hiren's CD and follow the instructions.There are very useful utilities CD and it a Linux boot CDwhich contains quite a lot of Utility programs including a password removalprogram.Click on one of these links todownload HIREN'S BOOTCD :-
http://www.hirensbootcd.net/http://67.20.82.163/
Asus Eee PC 1001p display black
Unplugged all the external device. Like external harddrive,Pendrive,Camera anything. And restart the computer in safe mode with networking. If it is working on safe mode you need to uninstall and reinstall the display drivers in order to fix the issue.
I lost my recovery partation
Hi you will need skillful guy to restore your PC Operating system if you had reformatted your hard drive. To restore your O/S without having your recovery CD is to ask from your vendor a copy of it and re-install again. You can do it by having an external DVD driver, change the boot sequence in start up and presto you can reload again your O/S and other applications. Don't forget btw to load the driver in order your PC to work properly.
Unable to restore
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the delete or F2 key
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart if this fails to fix the problem
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell what file has been corrupted or missing you might be able to work your way through problem if you are unable to find a solution
restart back into safe mode you might need to select your operating system to load into safe mode
click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred
you might use the system restore to restore your system to an earlier time
click start all programs accessories system tools you should see your system restore option
hope this helps you
I owned a asus 1001P
Welcome to Fixya
Freezing up issues usually caused by recent software installation, hardware modification or virus infection. Try to restore the computer back to the date where it is working fine as part of the basic torubleshooting. Power on the computer and keep on tapping F8 key. Select SAFE MODE then press enter. Once you are inside windows safe mode, click start menu then click all programs. Click accessories then click sytem tools. Click system restore then select a date where you remember your computer is working fine. Hope this helps.
Please let me know if you have further questions.
Thank you for using Fixya! If you need further help, reach me via phone at
https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
My notebook is having trouble to start
HI. Welcome to Fixya.
Restore from the Recovery Partition
- Start your netbook and tap the F9 key on your keyboard until you see a loading screen.
- The restore program prepares the files needed for the operation.
- A message appears asking if you want to perform the operation, you will lose all files on your computer.
- Confirm by clicking √.
- This will restore your netbook to factory settings and without any action on your part. Finally we should rather say the Ghost.
- At the end of the operation, the netbook will reboot on its own, and finish these configurations.
- A reboot is performed again, and you're on the setup process of Windows as the first boot after buying the netbook.
Hope this resolved your issue.
Thanks for contacting Fixya. Bye for now.
I dropped my Asus eee
Your LCD panel is cracked. It needs to be replaced. Generally physical damage to LCD panels is not covered under warranty by manufacturers, so you are better off going to a PC repair shop and have them order the replacement screen for you. If you are comfortable taking apart the system you should be able to find a replacement screen on ebay.
Tried to power up my
Please remove the RAM, Hard disk and battery. press the power on button for 1 -2 minites. then insert only one RAM on another slot. Start laptop with AC power. Whether is it displaying the NO BOOT DEVICE or not. If display no boot device, please insert the Hard disk. then try..
Hope this helps to you.
If your problem not solved, please let me know...
