20 Most Recent
ASUS K52JRA1 Notebook Questions & Answers
Can't remove dvd drive
Go to my computer, right click on it, > Properties > select drive> Properties > Hardware Tab > Driver > Uninstall
Blue screen with buzzing?
There is no way the motherboard was changed, the only thing I can suggest you try, sub out the ram memory one at a time, no change! pull out the hard drive and reseat it back in place that may fix the problem. If none of these work contact asus and tell them you are not happy with the repair and you want it fixed right.
K52j audio driver
easiest solution is to visit asus website. all drivers are on there
Only video, no audio from
Okay so I know this is a little delayed I had the same issue and what I found out by calling ASUS, is to right click on the speaker icon bottom right of screen, click on playback devices. If your HDMI is connected to both tv and laptop, then your TV should be listed. the speakers should have a green check, click on your TV then press set default, then configure test. After testing hit okay and you are good to go. You just have to turn it back to your laptop speakers same way. Good luck hope this is more useful than the typical "Check your manual."
I need a Hdmi driver
not all hdmi on laptops give the sound if you wanna try re-installing the driver go to asus website and go to support/drivers and enter your model number in
How to drag with mouse
Simply left click and hold on the item you wish to drag, then move the mouse to where you want it to be - then release the left mouse button.
