20 Most Recent
Dell Vostro 1014 Laptop Computer Questions & Answers
I have dell vostro 1014
Those are not simple problems. From your description, you probably gonna need to replace both the screen/flat cable and the keyboard (these parts just can't be repaired, must be replaced).
My hotspot software is always displaying error in soft ap
I also had the same problems in my laptop, but I had tried many ways, this problems couldn't be fixed. A friend told me maybe I need to reintalled the system. However, I didn't want to do. Finally, I tried to use other wifi software. A program named OSToto Hotspot can run. You can have a try!http://www.drivethelife.com/free-wifi-hotspot-creator.html
How to on bluetooth
Based on information provided, it seems that the issue might be with bluetooth driver or even with the driver for the function keys(Fn)
The best option would be to re-install the bluetooth and the function key drivers.
Please let me know if you need detailed information about the driver installation procedure.
Hope this helps..
How to use dell vostro as hotspot
Download "Connectifyme". It is a free version with other powerful options in paid version.
But keep in mind. You either need 2 wireless adapter, 1 for internet connectivity and 1 for hotspot.
Or, you connect to the internet via LAN port and wireless adapter for wireless hotspot.
Or, connect to the internet via LAN port to a wireless modem and hotspot with your builtin wireless adapter.
Let me know if you need more info.
Not on wifi
Hi to turn on the wifi you need to press the Fn + F11 keys together
Stuck completely while working
Reboot check taskManager you CPU is probably running at %100
you'll have to disable unnecessary start up items that are using up you're resources. Also you may need more memory.
to check start up run (msconfig) and click tab (startup) untick anything unnecessary.
Get lock 9 symbol come
2 days ago i was used windows7.But then my pc was very slow.so i thought that now i gate new setupso i try to get setup win732bit but still now i cant got set up.when i try to set up i found error massege.Then i try to format my local drive but i can\'t .befor when i get setup then it dont gate more time like now.Now it get more time but dont get setup.
How to format DELL Vostro 1014 Laptop
If you wish to FORMAT your hard drive so you can re install the OS.
Put your Windows disc into the CD/DVD drive, boot the computer and press F2 (if that does not work try CTRL+ALT and enter) to enter the bios. Change the boot order to boot from the CD drive first.
Follow the onscreen instructions to Install the OS, you should get the option to delete the existing partitions and then to FORMAT.
