20 Most Recent Infinity 50.5CS Car Speaker Questions & Answers
manual
3answers
I have a rover 214
Its possible that your ptoblem isn't in the ECU/PCM, so, the Inmobilizer Module go to bad...
This includes all Rover or Honda petrol engines, Peugeot or Rover Diesel engines, the older square shaped and the newer bubble shape.
Location of immobiliser ECU control box. Look above the pedals...
Rovers built before September 1995 on "L", "M" and early "N" suffered from key fobs losing the code, this can be rectified with a software update on the vehicle. The Rover 200 Immobiliser system is very reliable, the ECU control rarely fails, if your vehicle will not start it is probably due to the remote key fob. You may have to perform the above sequence if your vehicles battery has gone flat or it is disconnected.
The Rover remote key fob uses a rolling code system. When you press the key fob, the code changes every time, and the alarm box in your vehicle also changes its code to match with the key fob. This is a great antitheft system but sometimes the key fob and alarm box codes do not match and the system will not operate.
The most common cause for this is pressing the buttons on the key fob away from the vehicle, the key fob code moves on but the alarm box on the vehicle does not, so the two codes do not match. The key fobs and the ECU control box receiver on your vehicle have a clock, this clock also moves the code even if the key fob is not used.
Abbreviations
  • ECU - Electronic control unit, the box which controls the alarm, immobiliser and usually the central locking fitted to your vehicle, the immobiliser ECU is a separate unit under the dashboard.
  • EKA - Emergency key access, this number has no connection to the remote key fob.
  • MHZ - megahertz (frequency number).
  • ARMED - this is when you have locked your vehicle with the key fob, the alarm system is active and the immobiliser is on.
  • DISARMED - this is when you have unlocked your vehicle with the key fob, the alarm system is not active and the immobiliser is off.
The image on down, is the inside of the key fob, the most common problem when the key fob fails is the component circled. Very carefully check to see if the 2 wire legs are attached to the component and the circuit board.
Programming Lucas Key Fobs
When programming new key fobs, all key fobs are automatically erased from the ECU control box fitted to the vehicle. This is done because if you have lost a key fob or had a key fob stolen, the lost or stolen key fob will no longer work on your vehicle. At the time of programming all key fobs you need to work with the vehicle must be programmed.
The Rover 200 immobiliser system can have up to 4 key fobs programmed. At Remote key Ltd if a new alarm ECU control box or a new engine management ECU control box is required, they will need programming together before your vehicle will start. At Remote key Ltd we can carry out all the programming required, all this can be done on or off the vehicle.
Range/Distance Problems
Does you key fob not operate very far from your vehicle?
This can be caused by many factors. As we use more wireless electronic products, the radio waves interfere with each other and this is the most common problem when your remote key fob loses its range from your vehicle.
Remember!!!
Your Rover 200 relies on the remote key fob to start, get a spare. The remote key fobs get a hard life, they get dropped, damp, wet, hot, cold, we sit on them, when the remote will not operate, the problem will probably be the remote key fob.
If you disconnected the battery, its big possible that the "inmobilizer" system is armed; if this system is bad, you need to take the car to a Rover Dealer for it be done (to re-match ECU/PCM to 5AS Inmobilizer Module), there is no other way
Keep us updated.
11/23/2010 3:43:28 PM • Infinity 50.5CS... • Answered on Nov 23, 2010
I have a avionixx 3000 watt amp and 1 12cvr124 4o, 12in swiss swl 4o, 12 in infinity 4ohm how do I wire them
I'am making over $15k a month working online. I kept seeing how some people are able to earn a lot of money online, so I decided to look into it. I had luck to stumble upon something that totally changed my life. After 2 months of searching, last month I received a paycheck for $15376 for just working on the laptop for a few hours weekly. I was amazed how easy it was after I tried the copy below web...www.join.hiring9.com
2/22/2023 5:43:09 PM • Infinity Car... • Answered on Feb 22, 2023
Have a Infinity Systems HPS 250 Subwoofer. The gain control is bad. Can I get a replacement board and where?
Question edited for clarity, and order, 'make model (what it is)'. No spares suppliers listed, but try the maker on Page 13. https://www.manualslib.com/manual/76933/Infinity-Hps-250.html?page=13#manual https://www.google.com/search?q=Infinity+Systems+HPS+250+Subwoofer+parts Or any good electronics shop will have the individual part. Have you tried electrical contact cleaner?
2/20/2023 12:18:42 AM • Infinity Car... • Answered on Feb 20, 2023
Wiring 3dvc woofers to infinity refrence611a which way would it sound at its best and perform at it peek
Your question can't be answered without knowing the impedance of the subs. Are they 1 ohm, 2 ohm, 3 ohm, or 4 ohm coils on those dvc subs? Are you saying your amp IS 2 ohm stable?
1/28/2023 9:03:45 PM • Infinity Car... • Answered on Jan 28, 2023
What is the wiring schematics for an Infinity Gold Amplifier 56007499?
hi, if thats a dodge this might be it.. Re: Infinity Gold AMP Wire Diagram Well I don't particularly care for Haynes manuals, but my FSM's did not have anything either. I found this in thejeep cherokee haynes manual and it says that it is for 97 and later models but see if it is close. it looks like there are 2 harnesses so I will list them seperately: Hartness 1: [7] Left Soundbar Speaker (+) BR/YL [8] Left Soundbar Speaker (-) BR/LB [5] Left Front Door Spkr (+) DG [1] Left Front Door Spkr (-) BR/RD [9] Right Soundbar Speaker (+) DB/WT [3] Right Soundbar Speaker (-) DB/OR [6] Right Front Door Spkr (+) VT [2] Right Front Door Spkr (-) DB/RD [4] Power Amp Relay Feed DG/RD Harness 2: [05] Right Soundbar Spkr (+) TN/RD [13] Right Soundbar Spkr (-) TN/BK [06] Left Soundbar Spkr (+) WT/TN [14] Left Soundbar Spkr (-) WT/BK [11] Passenger Door Spkr (+) LB/RD [10] Passenger Door Spkr (-) LB/BK [04] Drivers Door Spkr (+) DG [12] Drivers Door Spkr (-) LG/RD [01] Power Amp Feed [02] Power Amp Feed [07] Power Amp Ground [08] Power Amp Ground The tweeters run in parallel off of the door speakers.... If I can help any more let me know. -Mike. https://forums.off-road.com/jeep-mid-sized/105694-infinity-gold-amp-wire-diagram.html
1/25/2023 7:13:52 PM • Infinity Car... • Answered on Jan 25, 2023
I have a infinity 56043029AJ 36670c amp need the wiring hook up
I'm assuming you're talking about the factory Infinity amplifier from a late 90's Chrysler/Dodge vehicle, and likely trying to reuse or repurpose this into another vehicle? See the attached photos for the wiring diagram of the stereo circuit with the amplifier, as well as the wiring pin-outs for both connectors inf_01-undefined-undefined-0.jpg inf_01_2-undefined-undefined-1.jpg inf_01_2-undefined-undefined-2.jpg inf_c1-undefined-undefined-3.jpg inf_c1-undefined-undefined-5.jpg inf_c1-undefined-undefined-4.jpg inf_c2-undefined-undefined-6.jpg inf_c2-undefined-undefined-8.jpg inf_c2-undefined-undefined-9.jpg inf_c2-undefined-undefined-7.jpg
1/13/2023 10:03:53 PM • Infinity Car... • Answered on Jan 13, 2023
How do I know if the amplifier of the 2005 Ram Infinity System is good or not? There is some test I can do, the radio turns on but you can't hear it
FACTORY AMPLIFIER IS MADE TO DRIVE THE SPEAKER IN THE VEHICLE IF NO SOUND YOUR AMP NEED REPLACEMENT
9/12/2019 4:19:19 AM • Infinity Car... • Answered on Sep 12, 2019
4answers
I need code of radio becker traffic pro high speed BE 7825
hy I have a becker traffic pro high and I need cod.serial BE7825 model 35001465
11/2/2018 12:38:36 PM • Car Audio &... • Answered on Nov 02, 2018
My 2002 Sebring with infinity amp had the factory radio plug cut off, I need to know what wires are what so I can hook up another head unit
what colours are those can you please specify them diff design for diff unit
12/5/2017 6:38:33 AM • Infinity Car... • Answered on Dec 05, 2017
I need a power cord for a infinity kappa 255a amplifier can you tell me where i can find one
hi Frank. if you go to this link have a scroll down the page and have a read up on what has been said about the amplifier you are talking about. Need power plug for infinity amp model 255 . plus i am finding out that you try ebay might help you but its not called a power plug. they are calling it a WECO connector..or.. U need to buy a cable, usually red and has a fuse. . or call the manufacturer.
11/22/2017 8:20:28 PM • Infinity Car... • Answered on Nov 22, 2017
Car Audio & Video Logo
3 questions posted
Top Infinity Car Audio & Video Experts
xxxxxx xxx
Sean Wright
Sean Wright
Steve Sweetleaf
Steve Sweetleaf
Are you an Infinity Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Infinity Car Audio & Video
Most Popular Question
rover 214
  • Car Audio & Video
