20 Most Recent
Motorola Mobility Netopia 2210 Residential Gateway Modem (RB2210002M022) Questions & Answers
I can not get internet
Internet light red =connection failed .
Reset your motorola modem(in the back of the modem),find the Factory Reset switch:
Carefully insert the point of a pen or an unwound
paperclip into the center of the switch.
Press for aprox 3-4 seconds ,the Modem will perform a factory reset, clear all settings
and configurations, and reboot.
If the problem persists, look for these possible problems:
Make sure the power adapter is plugged into the DSL Modem properly.
Try a known good wall outlet.
If a power strip is used, make sure it is switched on.
Make sure that any telephone has a microfilter installed.
Make sure that you are using the correct cable. The DSL cable is the thinner
standard telephone cable and labeled "Data Cable."
Make sure the DSL cable is plugged into the correct wall jack.
Make sure the DSL cable is plugged into the DSL port on the DSL Modem.
Make sure the DSL line has been activated at the central office DSLAM.
Make sure the DSL Modem is not plugged into a micro filter.
Make sure the you are using the yellow Ethernet cable, not the DSL cable.
The Ethernet cable is thicker than the standard telephone cable.
Make sure the Ethernet cable is securely plugged into the Ethernet jack on
the PC.
Make sure the Ethernet cable is securely plugged into the Ethernet port on
the DSL Modem.
Make sure you have Ethernet drivers installed on the PC.
Make sure the PC's TCP/IP Properties for the Ethernet Network Control Panel
is set to obtain an IP address via DHCP.
Make sure the PC has obtained an address in the 192.168.1.x range. (You
may have changed the subnet addressing.)
Make sure the PC is configured to access the Internet over a LAN.
Disable any installed network devices (Ethernet, HomePNA, wireless) that
are not being used to connect to the DSL Modem.
2/8/2011 4:19:39 PM •
Motorola...
Answered
on Feb 08, 2011
I'm trying to change my nat type from 3 to either
Windows 7 supports high definition graphics. So according to your problem first make sure your monitor is not too old model which does not support high definition graphics output.
check also your system even mother board graphics support.
set the graphics of your display from display properties in 1024:768 pixels or above. Use updated player which support HD video for your videos. If arise this problem for some of your graphical work or videos the check their system requirement. You may need a display card.
1/24/2011 10:53:48 AM •
Motorola...
Answered
on Jan 24, 2011
Como cancelar el winter driver
EnglishIt is a car, and cars are complexbut no car was told , maker, model , and year.we can not guess cars. post the VIN? and all that is knownname a problem what can't your car do right?name symptoms or evidence that is confusing to you.then answers can happen.onlygood luck , finding itand Mucho Gusto.my guess now is this is posted to computer forumand not to CARS !must be some odd traction controls thing'but 10,000 models of cars,
I need a product key
Have you actually purchased Visio, or are you just trying to get it for free?
As a software guy, I would have to advise against piracy. :)
There are several ways to get Visio for cheap. If you are a student, there are discounted versions available online and in stores. Also, you can check with your school for even cheaper options sometimes. Try the university bookstore if available. Or a Computer Science department maybe.
If you are working, and your company uses MS Office applications, find out if they have the "Microsoft at Home" program. You can get MS Office applications for really cheap that way. I can get Visio through my company's "Microsoft at Home" program for a few dollars.
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired an
employment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut.
They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
Solitaire master has a hang
clarify pi please. if you meant pi to mean main screen picture, you probably have used up your free time on this program.
