20 Most Recent ASUS RTN12 4 Port 10100 Wireless N Router 300MBPS with QoS Questions & Answers
0answers
I bought the router for just one month but I use
The ASUS Router is bad and just needs to replaced. If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
6/14/2017 11:46:10 PM • ASUS RTN12 4... • Answered on Jun 14, 2017
My asus n 12 router continues to reset to factory default. This is the second one to do this, anyone else' experience this?
if it continues to do that return it to the store where you buy it, and ask for replacement.
8/22/2012 4:56:52 AM • ASUS RTN12 4... • Answered on Aug 22, 2012
Hi, I have my RTN12 Asus wireless router set to
IRQL is usually the following:
bad ram memory
bad software driver for example: video driver
run www.memtest86.com
if it's bad ram replace it
if its a driver update your video drivers
4/7/2011 10:13:18 PM • ASUS RTN12 4... • Answered on Apr 07, 2011
Won't connect to blueray player
Go to service center...............
2/28/2011 11:41:07 AM • ASUS RTN12 4... • Answered on Feb 28, 2011
My i p adress has
Perform a Router reset
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the unit powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
Step 6 The device is now at factory defaults. Note: Do not recycle power during the reset procedure.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
1/23/2011 5:26:44 AM • ASUS RTN12 4... • Answered on Jan 23, 2011
When i'm trying to go into my settings for my
There should be a small reset hole in the rear of the router. Hold it in till the lights flash. This will set it back to default and erase the username and password. Then you can setup it up again. Here is the manual on this link:
http://www.asus.com/product.aspx?P_ID=xq8udon10ZTLU7o2 I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
12/6/2010 11:47:40 PM • ASUS RTN12 4... • Answered on Dec 06, 2010
When I try to set up my wireless network, I get
yes, in your windows you have your properties for your network card set with a static IP.
1. Go to the properties of the network and see if you have the dhcp set to "automatic" same as for the DNS
2. check your router for the same in the router usually going to a browser page and typing in 192.168.0.1 for most routers not sure what your is. check your router manual or go to the manufacturers page and get the instruction for your model.
10/5/2010 10:06:41 PM • ASUS RTN12 4... • Answered on Oct 05, 2010
2answers
Create a password for wireless internet connection
Hi. Open your browser and go to http://192.168.1.1
the default username and password is admin / admin.
Once you are inside the router, you will see on the left the menu such as network map, operation mode, advanced settings. Under advanced settings you will see the Wireless configuration where you can change the SSID (name of the wireless network) to any name you want. Then on the security you can select either WEP or WPA, i would recommend WPA and you set the password (letters and numbers or just letters) and save the settings and that's it.
Try to do this on a computer directly connected to the router (via ethernet cable) because any change on the wireless will disconnect you.
I hope this helps. Please do not forget to write and provide positive feedback for our fast/free support today. :D
5/25/2010 12:46:15 PM • ASUS RTN12 4... • Answered on May 25, 2010
ASUS P4S800-MX Error message STOP: 0xc00007b error during Windows XP installaton
Probably corrupt DLL files, maybe due to incorrect decompression or dirty CD.
1/22/2024 7:50:40 PM • ASUS Computers &... • Answered on Jan 22, 2024
My 4-year-old Chromebook laptop is getting slower. Is there a way to improve the performance of the Chromebook?
Run CCleaner
Download CCleaner
Download CCleaner for FREE. Clean your PC of temporary ... Run MalwareBytes Anti-Malware
Malwarebytes: Cyber Security Software and Anti-Malware
Malwarebytes https://www.malwarebytes.com Malwarebytes gives you protection you can trust, alerting you instantly when we see your information has been stolen. Our live agents can even help you restore ... Both have free versions, but I have bought both. Then go to Startup and remove TSRs (terminate and stay resident programs) that have been added by new programs. ..
1/12/2024 11:24:51 PM • ASUS Computers &... • Answered on Jan 12, 2024
2answers
How do I enhance my Asus PadFone X mini speaker loudness?
Look for a program called Sound Booster or one called DFX. DFX is my favorite because it not only boosts the volume, but lets you add other effects to enhance you sound as well. There is a free version. but to get all the effects you have to upgrade to the paid. If audio is important to you, check it out.
11/10/2023 2:08:22 AM • ASUS Computers &... • Answered on Nov 10, 2023
2answers
How to fix sound is not working in my asus laptop?
Try going into sound select and test reinstall driver off Asus website..if you installed new windows or update drivers may not work right...see if you can roll back driver in device manager ..if not lookup your laptop model and reinstall...
10/17/2023 10:59:01 AM • ASUS Computers &... • Answered on Oct 17, 2023
2answers
Asus Pro B53S No signal out hdmi or display port
Have you looked it up on the ASUS site? https://www.asus.com/support/FAQ/1015526/
10/2/2023 1:59:24 AM • ASUS Computers &... • Answered on Oct 02, 2023
Need wiring connections for asus M4a785-m motherboard.
Visit M4A785-M - Support (asus.com) and download the required manual.
9/19/2023 12:31:26 PM • ASUS Computers &... • Answered on Sep 19, 2023
Asus rog rg8 ii dont power up
6/23/2023 6:50:54 PM • ASUS Computers &... • Answered on Jun 23, 2023
Graphics card no picture on monitor when connected via HDMI or any cable?
The issue you are experiencing with your graphics card and monitor can be caused by various factors. Here are a few troubleshooting steps you can try to identify and resolve the problem: 1. Check power connections: Ensure that the graphics card has the necessary power connections properly connected. Some higher-end graphics cards require additional power connectors, such as 6-pin or 8-pin PCIe power connectors. Make sure they are firmly plugged in. 2. Verify BIOS settings: Access your motherboard's BIOS settings and check if the primary display output is set to the PCIe slot where your graphics card is installed. It should be set to prioritize the discrete graphics card instead of the integrated graphics (if applicable). 3. Update BIOS and drivers: Visit the Gigabyte website and make sure you have the latest BIOS version installed for your motherboard. Additionally, download and install the latest drivers for your graphics card from the XFX or AMD website. Outdated firmware or drivers can cause compatibility issues. 4. Reset BIOS: Try resetting the BIOS to its default settings. Locate the CMOS battery on your motherboard, remove it for a few minutes, then reinsert it. This action resets the BIOS settings to their defaults and may resolve any conflicting configurations. 5. Check for physical damage: Inspect the graphics card for any physical damage, loose connections, or faulty components. Ensure that it is securely inserted into the PCIe slot and that there are no visible signs of damage on the card or its connectors. 6. Test with a different monitor and cable: Connect your graphics card to a different monitor using a different cable (e.g., DisplayPort, DVI) to rule out potential issues with the HDMI cable or the monitor itself. This helps determine if the problem lies with the graphics card or the specific combination of monitor and cable. 7. Check for motherboard compatibility: Verify that your graphics card is compatible with your motherboard. Check the manufacturer's website for compatibility lists or consult the user manual for your motherboard. In some cases, a BIOS update might be necessary to ensure compatibility. 8. Seek professional assistance: If none of the above steps resolve the issue, it's advisable to contact the technical support of your motherboard or graphics card manufacturer. They may have specific troubleshooting steps or recommend further action, such as warranty service or component replacement. Remember to handle your hardware with care and take necessary precautions, such as grounding yourself and disconnecting the power supply, before performing any physical checks or adjustments.
5/29/2023 7:54:59 AM • ASUS Computers &... • Answered on May 29, 2023
I am using an Asus Vivo mini computer approx 5 years old. Since December I often receive error message across top, "Microsoft Edge (not responding)"
Question edited for clarity and toss in a load of CAPS as needed. Microsoft Edge is one of the worst browsers ever invented. It is flashy and looks pretty, but is not user friendly and is glitchy. The most likely issue for that Error Message is your Internet Wifi signal dropping out. You can test this theory two ways. Do you have a smartphone? Download the Free App Speedtest. When you get the Edge Error, whip out your phone and do a Speed Test. If it stalls or only returns a speed of 5 to 10 mbps, that is your issue. Or Download Google Chrome which is FREE and a much more robust browser and easier to use. Keep both Edge and Chrome open, when Edge collapses, try to do things on Chrome. If Chrome works, then the issue is Edge. If Chrome also fails, the issue is your Wifi and Router. A Router reboot should be done about once a month. Google Chrome Download - Download Google Chrome google.comhttps://www.google.com Continue your browsing experience from desktop to phone on Chrome. Download today. Now more simple, secure, and faster than ever - with help from Google built-in. Google Address Bar. One browser, all devices. Type less with autofill. Chrome support.
Download Now Get a new and fast web browser. Download Chrome and start browsing.
5/1/2023 7:50:39 PM • ASUS Computers &... • Answered on May 01, 2023
I inherited an Asus UX50V with Linux installed and would like to restore it to Windows 7.
The restore disc should have Product ID Key and that is all you need. Any password is entered after the install IF you want it password protected.
3/8/2023 5:01:53 PM • ASUS Computers &... • Answered on Mar 08, 2023
ASUS RTN12 4 Port 10100 Wireless N Router 300MBPS with QoS Logo
Popular Tags
13 questions posted
Popular Products
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • ASUS Computers & Internet
Most Popular Question
p adress
  • Computers & Internet
