20 Most Recent
Kyocera Mita FS-1020D Laser Printer Questions & Answers
ERR CODE E-0007 IN KYOSERA FS-1020
This question (which is factually not a question) needs more information. When does this happen?
Possibly an updated code. I can find E07 for Kyocera which means the printed document size/format does not match current paper size/format. Like you want to print A4 on Letter paper.
A black line is printing 6.5cm from the right side of the page
Clean the main charge, this is a step that is suppose to be done when replacing the toner but most people don't. The instructions to do this is in your users manual. If you dont have the manual go to
www.gfbm.net to download one. Also make sure the cleaner is placed all the way back to the right when done or it will effect your prints.
Kyocera fs1020d only prints 1/2 page?
needs realinded,remember the first set up,it printed a page,look it up online and run the start up series on it again,if not,you have a printer or roller bar stuck.
Waste toner clean
The waste toner in this printer is stored in the drum unit and you should replace the drum.
Every page jams in printer
This can be a number of problems depending on where the paper jams.Check and clean the feed rollers if not feeding into the machine.Ensure that you are printing to the correct size paper and that the cassette is correctly adjusted.If jamming in the interior under the drum then you may have an obstruction that the paper is hitting.If it jams just as it gets to the fuser unit then the fuser drive gear may have failed.
No lights dead
HiCheck the power cable or probably replace it.Press on the power button several times when unplugged from power.Plug it and try turning it on.
HOW can I reset ip
you can find it by searching with the software from the net card cd, when the printer is connected only through a hub or switch with the computer from which you ran the software.
