20 Most Recent Kyocera Mita FS 3800 Laser Printer Questions & Answers
This would indicate that either the developer ,Drum or Fuser requires attention .If you stop the paper before the fuser unit is the mark there? if not then it would point to the fuser unit.
Kyocera Mita FS... | Answered on May 19, 2016
Press Menu, scroll to Interface and press the right arrow key. Scroll using the down arrow and you should see the TCP/IP setting. Press the right arrow and turn off DHCP. Then you can move around to change the IP.
Kyocera Mita FS... | Answered on Apr 21, 2015
is there a corona wire sliding cleaner on the drum assy? if so it should be firmly at the correct end of its travel - on some printers if it is inboard it will print aline down the side
Kyocera Mita FS... | Answered on Dec 26, 2013
This error indicates a problem with user name, password or domain name. Username/Password or Shared Name/Folder Name. Domain name is not entered.
A complete list of kyocera error codes with description can be seen here:
Kyocera Error codes
Kyocera Mita FS... | Answered on Nov 22, 2013
Did you try the different types of envelopes in the : Properties / Device settings ? sounds like there is too much pressure for that envelope try changing the type of envelope and see if it makes a difference.
Kyocera Mita FS... | Answered on Apr 14, 2012
the best to do is to sent it to your nearest shop, if this is under warranty better to ask the technical inorder for you the prevent further damage on your printer. Hope it helps thanks.
Kyocera Mita FS... | Answered on Sep 15, 2011
Try cleaning the paper feed rollers for that cassette. Sometimes the rollers get dirty causing the paper to slip and not feed from the cassette causing the machine to register a paper jam.
The rollers can be cleaned with rubbing alcohol and a cloth.
Kyocera Mita FS... | Answered on Apr 15, 2011
Error 7000 indicates a toner motor error. If you are using a generic toner it could be that the motor is not strong enough to turn the gears on the toner cartridge. Try changing the toner first.
Kyocera Mita FS... | Answered on Mar 07, 2011
Download the service manual for your machine here, I took a look, and could not locate the F2 error:
FS_3800_manual
Also see other documents here:
FS_3800_support
Kyocera Mita FS... | Answered on Jan 15, 2011
Hi
Your motherboard on your print is not working
and must be replace it
the cost of it is to high
you better replace your printer
Kyocera Mita FS... | Answered on Nov 25, 2010
Hello there,
Unfortunately, Fixya does not provide crack keys as it is illegal. Using pirated softwares also takes away from you the privilege of having a regular update for security holes and bug fixes for the operating system. Please take not also that by using illegal softwares, it also punishable by law.
To obtain one, you need to purchase a valid license key.
Kyocera Mita FS... | Answered on Aug 17, 2010
Kyocera Mita FS 3800 Laser Printer Logo
59 questions posted
Top Kyocera Mita Office Equipment & Supplies Experts
Adorjani Laszlo
AAAA262430
Marvin
Marvin
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Kyocera Mita Office Equipment & Supplies
Most Popular Question
hooking up kyocera fs3800 printer imac
  • Office Equipment & Supplies
