20 Most Recent Kyocera Mita FS-C5016N Printer Questions & Answers
On the back of the printer.
Kyocera Mita... | Answered on Apr 27, 2016
failure of developer unit or will require developer replaced in machine
Kyocera Mita... | Answered on Aug 03, 2014
go into your print driver properties and set it to spool...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Kyocera Mita... | Answered on May 11, 2014
the power supply of the printer gone bad, needs to be repair from authorzed service center
Kyocera Mita... | Answered on Jan 08, 2013
you most likely will need to replace the magenta developer...
you prob dont' need a tech to do this..
these machines get very dirty..
take out all the toners.
underneath the toners is the developers.
there is a connector on the right hand side ..take out the connector
than pinch both grey tabs together and pull up and out the magenta developer... clean the magenta develop (vaccum out) or replace it
Kyocera Mita... | Answered on Sep 07, 2011
Possible failure of the main power supply unit which is a switch mode power supply.( SMPS).
You need to disconect the power supply to the printer and open the panel to check the SMPS unit.
Please check on the link below for tips to check the SMPS unit. If this is not possible check with a power supply unit to confirm before you order.
https://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Kyocera Mita... | Answered on Jul 29, 2011
Hi misterqm,
  1. From from you have mentioned, I understand that that there has been a fault in your printer's software programming , this is usual for such "contact service" errors, this error not just come up in printer , but also in mobile phones and other such electronic devices.
  2. I would recommend you to take the printer to the authorized service center so that they can repair it for free if it's under warranty or guarantee , or they may replace this as a defective production.
  3. Please make sure you don't open up any seals on the which exist on the printer to not void warranty , in case it's still under warranty.
  4. If it's not under warranty , then you should take it to the kyocera service center so that they can re-install the software in your printer for you.
Hope this helps ... :) Your feedback would be appreciated.
Kyocera Mita... | Answered on May 16, 2011
It could be a fuser, drum, developer, or transport belt problem among other things. The FS-C5016N is an old model color printer and if the maintenance kit has not been replaced it probably should be. THe maintenance kit contains the items above along with a few others.
Kyocera Mita... | Answered on Mar 30, 2011
push the power button.
Oh make sure its connected to the mains
Kyocera Mita... | Answered on Feb 10, 2011
PLS REPLACE DRUM IN THE Y BLOCKS TONER..........
Kyocera Mita... | Answered on Feb 03, 2011
This will either be the fusor or the image drum.
The fusor is just the heating unit that melts the plastic toner onto the paper. If this is going out then the printed edge that is fading out should be rough or even dusty. You should be able to rub off some of the print. If thats the case then this needs to be replaced.
If the print is normal (ie it all sticks and isn't dusty) then it is being caused by the image drum. That is going to be real expensive to replace compared to the toners.
The last thing that I can think of that causes this is that the toner is not even in the cartridges. Usually you only get this if the toner clumps or you have printed a lot along that side or the printer has been bumped or knocked. You can fix this one if there is enough toner by taking the carts out giving them a side to side shake to even out the toner and put them back in. Just make sure to keep them level as much as you can. The toner is a real fine powder than can flow or move.
Kyocera Mita... | Answered on Feb 02, 2011
The display just indicates the default interface. If you have everything connected properly and send a print job to the printer it will automatically switch and print out. The default interface can be changed but there is no need to for your application.
Kyocera Mita... | Answered on Jan 19, 2011
Kyocera Mita FS-C5016N Printer Logo
49 questions posted
Top Kyocera Mita Office Equipment & Supplies Experts
Adorjani Laszlo
AAAA262430
Marvin
Marvin
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Kyocera Mita Office Equipment & Supplies
Most Popular Question
kyocera fs c5016n wont power up
  • Office Equipment & Supplies
