20 Most Recent
APC SURT1000XLI 1000VA 700W 230V UPS (SURT10000XLI) UPS System Questions & Answers
Surt10000xli not switching on
my ups surt10000xli ups shows internal faulty LED On, i have checked main board but couldn't find the fault. please tel me the fault
How to replace an apc battery back up battery
Depend on model.
For 600VA and above
Go to APC site and check model of replacement battery.
Peel open the front plastic panel and unscrew 2 screws of metal panel.
Batteries can be slid out and replacement done when PC is online.
Only two wires to disconnect and connect.
HELP! See details please
I would replace batteries, they do not have a long life.
beeping The Back-UPS product has entered a low battery condition - This alarm indicates that the UPS has reached a Low Battery condition and will soon shutdown. The UPS can only operate on battery for a limited amount of time.
clicking
copy and paste link
https://www.apc.com/us/en/faqs/FA158813/
Where can I get transistor GP4063D/ IR 214 for APC UPS IS1244003099
You can purchase electronic components, such as the GP4063D/IR214 transistor, from various electronic component distributors such as Mouser, Digi-Key, Arrow Electronics, and more. You can also check with local electronics retailers or online marketplaces such as Amazon or eBay. It is best to check the availability of the specific component with multiple suppliers to ensure that you can get the component you need in a timely manner.
APC BK650EI 650 VA 400 Watts (1) IEC 320 C13 (Surge Protection) (3) IEC 320 C13 (Battery Backup) Outlets Back-UPS CS 650 USB/Serial. It blinks random orange LED.
I say yes he manual shows ,setting sensitivity here.
the sound like charger fail. Inside.
inverter works, did you let it charge overnight first.
and disable the beeper if annoying.
is AC line voltage low? that too can beep.
is this USA model 120vac or outside USA>
also if the UPS is for another country that will be bad.
650EI , is not the E means European version"??? why skip country.
>? and matters huge that.
EI is 230vac version, and will be wrong used in 240vac countries and worse.
yellow led only blink is low line AC as the manual tells
my guess you bought the wrong UPS?>
v2 docs but not told version
page 2.
https://download.schneider-electric.com/files?p_Doc_Ref=SPD_AHUG_990-9237_EN&p_enDocType=Quick+start+guide&p_File_Name=BU+UM+990-9237B+MN01+EN.pdf
My power supply APC UPS-ES 700 won't power on ,at all .
APC.com have many here.
there are fuses inside that blow too.
not just the rear breaker.
fails with NO Loads cables connected at all?
1: batteries shorted or dead. short overload it .
there is a battery fuse, easy or hard to find ,easy on my loved
smt750C.
the true model of you UPS is not front stamps
but the rear label tells the truth.
2: turn it on with not batteries yet, some turn on with error light or on mine LCD hard text errors,. no bats.
3: that is about it besides bad PCB.
ES-700 those pan-cake UPS. sure.
batteries do fail for sure out of the blue. (plates inside can short)
out of the blue. or one cell goes dry and open and dead.
the battery fresh pulled will read 13.0vdc. (good UPS)
not 10
not 1, not 0
13.
or 12.8v min. rested 5 hours post charged.
the brain inside (firmware) is not very smart.
it see's any errors it does not like and turns off fast.
blink of eye fast . it can.
shorts , or battery seen shorted.
or blows fuse, deep inside on PCB
up to 400volts inside do not touch that with hands, lethal
are you on 240vac? we are 120v here.
Why won't the new battery allow the xs go on line
let it charge overnight, (new real or new from ebay not new)
never assume it is charged new.
make sure rear AC circuit breaker on it is not tripped
makes sure battery fuse not blown
make sure battery lugs not rusty.
learn how to bench charge any AGM battery like this at 3amps max,
? (AND ATV CHARGERS IS WOW HERE)
2004 UPS, many were recalled for not having fuse. on the battery feed. and cause smoke. why use 15-04 -11 year old UPS>?
MOST THAT OLD HAVE BIG PROBLEMS.
OWNERS MANUAL FOR BR1500LCD
apc.com (step 1 tell them your country first, seems you did not.)
most easy question on earth . and answered.
in usa most APC were banned in jan 2022, a horror here,
most discontinued are still supported with manual and software.
not deleted. for even 10 or more years.(found it)
i can not decode your model (i guess BR is the code)
on the rear or side off UPS is a white sticker or service tag
for sure and you did that I see.
and on such tag is the real model number even encoded for country .
and your unstated countries voltage line input.
APC BACK-UPS RS BR1500LCD 1500VA/865W UPS System(2006 made)
are you in barbados posted to N.Amercias'/
if yes learn to only go to APC site for your country of find nothing you will.....
seems not sold in many countries but is old.
https://download.schneider-electric.com/files?p_File_Name=ASTE-6Z7VAU_R0_EN.pdf&p_Doc_Ref=SPD_ASTE-6Z7VAU_EN&p_enDocType=Quick+start+guide
Model 420 Pro. Why is output only 84 VAC?
no real model told , off rear sticker, (tell sticker model first)
420va
no country told
no line voltage told in your country
Did you buy the ups from wrong country(oops) and it has
higher input voltage spec and yours is lower input? (real)
nobody can guess what's up there.
history and all that and location,
voltages are not the same word wide at all
nor frequency 50/60Hz
did you buy a used UPS.
if yes from where ebay, and from wrong country
or it ran for years and fails now.
or outputs overloaded on it.
