20 Most Recent
Kyocera Mita FS-1920 Laser Printer Questions & Answers
Everytime i turn it on,
go to menu paper handling- mp tray mode start from there.........disable or something long time but will fix
Kyocera FS-1920, error F030:0077538
i've been working on kyocera's for about 4 years. now..this error is not good..it's a general system failure..only solution is replacing main board.
contact me if you need a part #.. I can look it up for you
Background printing
This can be caused by not using genuine toner. Drum,developer or fuser unit may require replacing.
Hi, just wanting to know
open 2 screws at the top cover remove the cover take a soft wipe comes with the unit or any soft clothe and wipe gentle
How to add fs-1920 printer to HP300 pc
depending on u're OS you can use a wizard from printer and faxes for win xp and win7 or using installation cd. connect the usb cable or parralel cable switch on the printer the found new hardware appears continue with installation select u're model kyocera->fs1920 or nearest model-> then follow instructions
Printing blank paper
check if the developer is opened before fixing open two screws on the top cover and clean the underlying glass screen which snap the image
