20 Most Recent
Kyocera Mita KYOCERA/MITA - KM-C3130 Printer Questions & Answers
I was on-line yesterday and the terch had me try
This is a hard disk error. When we were troubleshooting yesterday you said you were going to try and disconnect some sensors to by-pass the problem with the Image Units. Did you put them all back? This hard disk error states that it can not communicate with the built-in hard disk.
Jim
Preston Computer Services
www.prestoncomputerservice.com
C-0991 error on screen
First problem is for some reason your KMC 3130 crosses over to a Konica Minolta CF3102 and there is no C-0991 code listed for those machines. However, that C-0991 code is a common paper tray lift failure code on Konica MInolta machines.
So I would recommend opening and checking all of your paper trays to make sure nothing is binding them and that the paper is loaded properly.
Then open and close the large front door to reset the code.
If the code comes back then open all of your paper trays and LEAVE them open. Next open and close the front door to reset the code. The copier should now come to "ready to copy"
Then close each paper tray 1 at a time waiting 30 seconds between each tray closing. Once the code pops back up after closing a particular tray then you will know for sure which tray is causing the problem.
You can use the copier by leaving this tray open if need be.
Good Luck.
Error C-0012, what do this means?
mhn arahan untuk problem yang saya alami dalam pengoperasian hp officejet 7210 all in one -
problem : kedua tinta hp black print cortridge 96 dan hp color treecolor 97 uda di masukan kedalam kotak atau wadahnya, namun, perintah yang keluar adalah : remove and check color cartridge mhn arahan tks
Error code j6301
Adjust the finisher to the upper limits to resolve. The height from the factory is too low. Paper curl from moist paper will cause this jam code 6301.
Code c 610
You have not mentioned the modelThis error code means that the dim is at fault or requires re-seating into the machine.
