20 Most Recent Kyocera Mita KM 1510 Laser Printer Questions & Answers
Toner container problem
Toner level is not detected when toner
empty is detected.
Check the connection of connector YC5 on
the engine PWB and the continuity across
the connector terminals. Repair or replace if
necessary.
Defective toner
container sensor.
Replace the toner container sensor.
Kyocera Mita KM... | Answered on Dec 11, 2017
hello error concerns that there is insufficient fusion temperature, heat lamp revises open position and condition of the thermistor and thermostat connections general..etc
1087 1087 to enter with pressing (163) / print> stop / clear you press (001) and ready.
Kyocera Mita KM... | Answered on Sep 08, 2016
4 Slide the toner container to the left and then pull it out toward you. 5 Gently pull the cleaning shaft out as far as it will go and push it back in 2 to 3 times. IMPORTANT Do not pull the cleaning shaft with force or pull it out completely. 6 Hold the new toner container vertically and tap the top 15 times. Turn the container upside-down and tap the top 15 times. Then, hold the container horizontally and shake it from side to side 10 times. WARNING High voltage is present in the charger section. Take sufficient care when working in this area, as there is a danger of electrical shock. 7 Install the toner container. * First insert the toner container into the copier as far as it will go and then slide it to the right as indicated by the marked arrows.
Kyocera Mita KM... | Answered on Mar 07, 2015
Toner is being replenished inside the copier. Wait a few minutes. * Although the lamp under the platen may remain lit while "AP" is displayed, it is not a problem.
also try taking out toner cartridge and shaking it a few times,
it may be clumped up or empty.
polygon motor problem-bad laser unit
Kyocera Mita KM... | Answered on May 30, 2014
C 710 is a Toner Sensor Problem
Defective toner sensor - Replace toner sensor
Poor contact of the toner sensor connector terminals - Reinsert the connector. Also check for continuity within the connector cable. If none, repair or replace cable.
Developer problem - Replace developer.
Kyocera Mita KM... | Answered on Nov 13, 2013
Broken fixing heater wire
• It takes 15 s or more for the fixing temperature to reach 50°C/122°F after the power is turned on or the safety switch is turned off and on.
Fixing unit thermistor installed incorrectly.
Check and reinstall if necessary.
• It takes 10 s or more for the fixing temperature to reach 100°C/212°F from 50°C/122°F.
• It takes 24 s or more for the fixing temperature to reach the secondary stabilization fixing temperature from the primary stabilization fixing temperature.
Fixing unit thermostat triggered.
Check for continuity. If none, replace the fixing unit thermostat.
Kyocera Mita KM... | Answered on Mar 30, 2011
It sounds as if the paper size at the machine is set incorrectly. Try checking to ensure you cassette or bypass if that is where you are printing from is set correctly.
Kyocera Mita KM... | Answered on Feb 18, 2010
Unfortunately it is the laser unit that has failed. And these unit's aren't a servicable item.
Kyocera Mita KM... | Answered on Jun 30, 2008
You have not mentioned the model
This error code means that the dim is at fault or requires re-seating into the machine.
Kyocera Mita... | Answered on Oct 07, 2019
problem for km 6030, optimizing performance
Kyocera Mita... | Answered on Jun 06, 2019
Hello sir; Just follow my instruction, I will help you to get rid off the error code; With front door open press10871087 then enter 163 press "start" key, final press " stop/clear " key to get out reset procedure.
Kyocera Mita... | Answered on Jul 19, 2018
Kyocera Mita KM 1510 Laser Printer Logo
Popular Tags
22 questions posted
Top Kyocera Mita Office Equipment & Supplies Experts
Adorjani Laszlo
AAAA262430
Marvin
Marvin
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Kyocera Mita Office Equipment & Supplies
Most Popular Question
kyocera mita km 1510 am getting
  • Office Equipment & Supplies
