20 Most Recent
Kyocera Mita KMR-1810P Laser Printer Questions & Answers
Error c630 cual es elfusor
you have to clear Resetting the fusing problem dataDescription
Resets the detection of a service call code indicating a problem in the fusing section.
When a service call concerning the fusing section occurs, turn the power switch off and open the front cover.
Then, turn the power switch on and press the system menu/counter key to enter the maintenance mode.
Purpose
To prevent accidents due to an abnormally high fusing temperature.
Method
1. Press the enter key. A selection item appears.
2. Select Execute using the up/down cursor keys.
3. Press the enter key. The fusing problem data is initialized. (Four service calls, namely C6000, C6020,
C6050, and C6400 are reset.)
Completion
Press the back key. The indication for selecting a maintenance item No. appears.
AP Code
it means Add Power aka toner out
Print Quality
clean the transfer roller and inside the printer .........
UNKNOWN CODE
when ap code is coming add toner. when the toner is empty this code displays.
