20 Most Recent Kyocera Mita KM-5035 Printer Questions & Answers
Fuser unit Error code, you can try to reset, but if the code still there, you need to change the fuser unit.
This is the way to reset your fuser code;
On the panel press 1087 1087
this will take you to the service mode,(look into the screen)
now on the panel again press 163 and hit the start key.
Look in the screen, you will see execute, select execute by the arrow and hit the start key, the machine will turn off then on. or it will ask you to turn the main power off than on. this might fix your problem, if not! change the fuser.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Kyocera Mita... | Answered on Oct 27, 2019
Main charger problem
Kyocera Mita... | Answered on Dec 11, 2017
Have you tried a new cartridge?
Kyocera Mita... | Answered on Jun 22, 2016
there are many reasons for this .first make sure you installed the toner container very well. second type 1087 twice to service menue then type 30 to chick motors then exit and type 130 to adjust toner mode when the machine stop turne it off-on
Kyocera Mita... | Answered on Jan 17, 2016
press10871087 after press163 reast
Kyocera Mita... | Answered on Dec 24, 2014
my dear selct ip adress
When replacing DC/main PWB or engine board, be sure to remove the EEPROM from DC, main PWB or engine board that has been removed and then re-attach it to the new DC/main PWB or Engine PWB, cheers
Kyocera Mita... | Answered on Aug 28, 2014
waste toner motor error, under cover on right side of machine, will have to be replaced. also motor could of damaged PWB.
Kyocera Mita... | Answered on Aug 03, 2014
reset fuser error , via service mode
This code means that there is a problem with the fuser unit
Kyocera Mita... | Answered on Jul 27, 2014
Error C7400 on Kyocera km 5035 is Image formation unit problem or connector
Hope this will help
Kyocera Mita... | Answered on Jun 17, 2014
drum or development unit need replacing!!
Kyocera Mita... | Answered on May 30, 2014
Go through the maintenance procedures in your manual. All cleaning should be done which probably includes roller cleaning but you should run it through all the procedures.
Kyocera Mita... | Answered on May 01, 2014
Could be the paper full tab is "stuck up" at the exit, or at least unplug the finisher from the unit and cycle power, pull away and see if it prints. -Carl
Kyocera Mita... | Answered on Apr 30, 2014
1. need to get the IP address of the printer, print a configuration page from the printer and that should have it on it
2. open up the add a printer wizard and for the port you need to create a new tcp/ip port with the ip address of the printer
3. you need to have the drivers available on your computer to complete the addition of the printer
let me know if you need clarification on any of these steps
Kyocera Mita... | Answered on Apr 06, 2014
Kyocera Mita KM-5035 Printer Logo
115 questions posted
Top Kyocera Mita Office Equipment & Supplies Experts
Adorjani Laszlo
AAAA262430
Marvin
Marvin
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Kyocera Mita Office Equipment & Supplies
Most Popular Question
replacing dc controller board
  • Office Equipment & Supplies
