20 Most Recent Kyocera Mita KM-2050 Printer Questions & Answers
reseat orignals on DP.
Kyocera Mita... | Answered on Oct 30, 2019
It just means take all the pages out of the document feeder on top and put the whole complete document in again
What cable usb or network cable
Kyocera Mita... | Answered on Dec 29, 2018
your error is : C210 Paper conveying motor
check paper motor remove and check clean with alcohol and than oil it
Kyocera Mita... | Answered on Dec 08, 2018
need firmware update. will have to be done by factory tech
Kyocera Mita... | Answered on Jul 20, 2018
C3100 Scanner carriage problem
• The home position is not correct
when the power is turned on or copying
the document placed on the contact
glass. Poor contact of
the connector terminals.
Defective scanner
home position
switch.
Defective engine
PCB.
Defective scanner
motor.
Kyocera Mita... | Answered on Jul 12, 2018
MR KIRAN now which type of error is that the machine showing alert mi soon you will get immediate answer thanks
Kyocera Mita... | Answered on May 12, 2018
heater problem press10871087 after press 163 reast
Kyocera Mita... | Answered on Mar 23, 2018
Zero-cross signal error
While fuser heater ON/OFF control is
performed, the zero-cross signal is not
input within 3 s.
fuser related problem
Kyocera Mita... | Answered on Dec 11, 2017
Polygon motor synchronization problem
The polygon motor does not reach the
stable speed within 20 s of the START
signal turning on.
Poor contact in the
Check the connection of connector YC3 on
the engine PWB and laser scanner unit, and
the continuity across the connector terminals.
Repair or replace if necessary.
Defective polygon
motor.
Replace the laser scanner unit.
Defective engine
PWB.
Replace the engine PWB and check for correct
operation.
check your fuser unit thermistor or thermostat or lamp as the following digita 1087 1087 and put 163
Kyocera Mita... | Answered on Sep 08, 2016
Are you low or almost out of toner? If that isn't the case then I would call on your local servicing dealer. It could be a problem with the developer unit or it could be something simple. You won't know until a technician looks at the MFP.
Kyocera Mita... | Answered on Aug 02, 2016
The scanner under the glass is jammed.
Kyocera Mita... | Answered on Apr 27, 2016
The default code for the Kyocera KM-2050 is 6482.
Kyocera Mita... | Answered on Mar 13, 2016
This error code due to laser unit problem
Kyocera Mita... | Answered on Dec 11, 2015
Kyocera Mita KM-2050 Printer Logo
188 questions posted
Top Kyocera Mita Office Equipment & Supplies Experts
Adorjani Laszlo
AAAA262430
Marvin
Marvin
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Kyocera Mita Office Equipment & Supplies
Most Popular Question
lost pin code kyocera 2050
  • Office Equipment & Supplies
