20 Most Recent
Konica 7075 All-In-One Laser Printer Questions & Answers
Konica coppier 7035 (F-26-1 error)
Replace the developer and the drum and clean the sensor that monitors the drum. and after developer is replaced ensure you run the required procedure in 36 mode.
C34-01 how can fix it?
Power off the machine. 10sec then power on. with the 2 and 5 button held down.. When screen appears select soft switch settings. in the next screen place 3 in left box, a 1 in the middle box and change the third box from 1 to 0. exit power off. Wait 10 sec. Then power on if the code comes back do not attempt another reset the code you are clearing is for the hot part called a fuser. It can catch on fire, that would ruin a perfectly good day.. Have a tech look at. Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/normanj_7893313f0751935f
Code sc35-01
Power off. Power on with the 2 and 5 button held down when screen comes on select soft switch on that screen in the left box place 3 middle box place 1 third box change the 1 to a 0. exit power off. wait ten seconds power on. if the code comes back do not reset that code you are clearing is the fuser the hot part it can catch on fire! (Would ruin a perfect day!) Have a technician look at it. Btw, I’m available to help over the phone in case u need at
F-35-9
F-35-9 means fixing unit problem, check the heater lamp & temp. fuse/thermostat of it.
Konica royal 2803 zmr
First return the Cleaning unit (color black @ left side) you will see 2 shaft at the drum carriage lower the cleaning unit but dont lock( 2 lever w/ spring) it, then put the Selinium Drum then insert the shaft. Next the developing unit right side and screw it. Engage now the cleaning unit make sure the lock insert the hole both side. Then put on top of the drum the charging corona & CEL. In sert the whole drum carriage inside the copier . good to go
Konica 7075 paper drawers wont open
The 7075 uses a solenoid interlock on all the drawers. The machine must be powered up and not have a jam indicated between the drawer and machine main body. It also will only allow one drawer to be open at a time. There is a manual release lever on the left side of each drawer. The lever is accessible by opening the long, skinny left front door.
Use as printer konica 7075
you have to have the optional print controler IP601
How to setup a konica to print lpr .
- Click start then printers and faxes
- click add a printer
- click next
- make sure local printer attached to this computer is checked and uncheck the box for automatically detect and install my plug and play printer and click next
- click on create a new port and on the drop down box next to it select standard tcp/ip port. Click next.then next again
- enter the printer ip address and click next
- click custom and then settings.
- click lpr enter the queue name: print and make sure to check mark the box that says lpr byte counting enable and click ok
- click next then finish
- click have disc then browse for the driver disc and install the driver by clicking next tell it if you want it to be your default or not and click nexttell it you want to share and try to print a test page by clicking next then finish then ok for the test page popup
Quality Issue
When was the last time a PM kit was installed?
I am actually factory trained on that model, and what you're describing sounds like a bad charge grid (which comes in a PM kit). Any contamination on it will cause intermittent "hazing" and streaking, which seems to come from no where.
Also, there are a few "tricks" I remember on these. If the tech is familiar with these machines, i'm sure he knows them.
One crucial thing is that he performs the HV auto adjustments.
Don't forget to clean the write unit mirror that Konica conveniently hid up inside the machine above the drum carriage..
If you need more help, please don't hesitate to ask.
Error code c-3401 on konica c1070
Hi!
The C-3401 error code on the Konica Minolta C1070 typically indicates a fusing pressure release failure. Here are some steps you can follow to troubleshoot the issue:
- Turn off the printer and unplug it from the power source.
- Wait for at least 10 minutes to allow the fuser unit to cool down.
- Open the front door of the printer and remove the fuser unit.
- Check the fuser unit for any damage or signs of wear and tear, such as cracks or scratches on the surface. If you find any damage, you may need to replace the fuser unit.
- Check the pressure release mechanism inside the printer to ensure it is working correctly. The pressure release mechanism should be able to move up and down freely.
- Reinstall the fuser unit and ensure it is correctly aligned.
- Turn on the printer and check if the error has been resolved.
If the C-3401 error persists, it is recommended that you contact an authorized Konica Minolta service technician for further assistance, as the issue may require replacement of parts or other more advanced troubleshooting.
Regards
C-3303 error konica how to fix?
The C-3303 error on a Konica copier typically indicates a problem with the cooling fan. Here are some steps you can take to try and fix the issue:
- Check the fan: Open the copier and check the cooling fan to see if it's running properly. If it's not, check for any obstructions that may be blocking it or any loose connections.
- Clean the fan: If the fan appears to be running but the error persists, it may be dirty and in need of cleaning. Turn off the copier and unplug it before attempting to clean the fan. Use a soft brush or compressed air to remove any dust or debris that may be clogging the fan.
- Replace the fan: If the fan is damaged or not functioning properly, it may need to be replaced. Contact your Konica technician or authorized service provider to order a replacement fan and have it installed.
- Reset the error code: After addressing the issue with the cooling fan, reset the error code by pressing the "Function" button followed by "Clear" and then "Err". Enter "OK" to clear the error code and restart the copier.
If none of these steps solve the issue, it may be necessary to have a professional technician diagnose and repair the copier.
How to solve konica 3070 error C-6102?
I strongly believe you can fix the C-6102 error code by the following;
The C-6102 error code on the Konica Minolta Bizhub 3070 printer is related to the fusing unit. The fusing unit is responsible for melting the toner onto the paper to create a permanent print. When the fusing unit becomes damaged or is not functioning properly, it can trigger the C-6102 error code.
To resolve the C-6102 error code, you can start by checking the fusing unit for any visible damage or wear. If you find any, you will need to replace the fusing unit. However, if the fusing unit appears to be in good condition, you can try cleaning it to see if that resolves the issue.
To clean the fusing unit, you will need to remove it from the printer and then clean the thermistor and the thermistor sensor. The thermistor is a small resistor that measures the temperature of the fusing unit, while the thermistor sensor is a device that reads the output of the thermistor. Over time, dust and debris can accumulate on these components, which can cause the fusing unit to malfunction.
To clean the thermistor and thermistor sensor, you can use a dry cloth or compressed air to remove any dust or debris that may have accumulated. Once you have cleaned these components, you can reassemble the fusing unit and reinstall it into the printer.
After you have cleaned or replaced the fusing unit, you can power on the printer and check if the C-6102 error code has been resolved.
