20 Most Recent
Samsung LN55C650 TV Questions & Answers
Hi
I have a Samsung LN55C650.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
What is the remote code to access the service menu on a Sansung ln55c650?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Search the site by type in the "
brand name" to your device, in the "
Search box at the top right of the display window of the Homepage" to get gathered related posts.
The backlight on my Samsung ln55c650 goes out after being on for a short time.
Samsung LN55C650 picture is dim on the right side
Hi, this sound like the same fault as i had, our tv only had half the screen go off also, the right side, after looking up on the internet i found a video for a fix, what you need to do is remove the back cover, there will be ribbons that go from the front screen to the main panel, i removed each one at a time and rubbed the contacts of the ribbon with a rubber on the end of a pencil, plugged them all back in and switched it on and it was now spot on, thats more than a year ago and its still working spot on, hope this helps
jim
Intermittent change of resolution.
Sounds like nothing more than a tcon cable connection. I would try unplugging then plugging the cable connection to the tcon and also the two upper tcon cables that are located under the Tcons metal cover.
New device not found/ usb2
I called 1-800 SAMSUNG and they had a firmware update that fixed the problem. I don't know if the update is available on their website, as I had downloaded a firmware update 2 days previous and this was a newer version that they sent me via email.
Screen has started to flicker constantly. tv is
I had the same issue occur on my ln55c650 and they had to replace the power supply pc-board. Seems some issue with power module in the TV rather than the side panels. Luckily for me, TV was still in warranty.
Ln55c650 flashe s
The Problem is with the power supply. It needs to be replaced. It is having abiasing problem that causes the backlight to flicker or strobe
