20 Most Recent Samsung LN40C650 TV Questions & Answers
Hi, I had the same issue for the past few days on my Samsung Blu-Ray player which has InternetTV. The only way I could fix it was by doing a factory reset of the device and the set everything up again.
Samsung LN40C650... | Answered on Nov 11, 2019
I know this is an old thread, I just picked up a Samsung BD5100 for
$15 off of ebay. The only thing I will be doing is connecting up to
netflix. I have it cabled directly to a netgear router. First tried it
with a 25 foot ethernet cable, it failed the gateway ping test. Tried
messing with the a few router settings without success. I put a 2
meter ethernet on, bang, works like a dream, Power cycled the
router and the player several times, just to make sure this wasn't
a fluke. Apparently the network timing is right on the edge. I know
my 25 footer works, it runs to my laptop just fine. The player does
have the latest firmware release. So my solution is to move my
entertainment center a bit closer to my router, ohh boy!
Samsung LN40C650... | Answered on Mar 04, 2013
On ALL inputs video sources? Solid color lines?
Need more info since it is still under warranty.
Can you post the pictures so we can see exactly what it looks like?
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Samsung LN40C650... | Answered on Jan 13, 2011
The problem is the LCD panel went bad, it can't be repaired, you have to replace it.
Samsung LN... | Answered on Jan 16, 2018
back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Samsung LN... | Answered on Nov 18, 2016
Caps can fail with no outward signs. It takes a special meter to test them. Your set may have a back light inverter that powers the back lights. When it fails, the picture cant be seen, but you have sound, to check this look for a picture on the screen using a flashlight
Samsung LN... | Answered on Mar 17, 2016
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
Samsung LN... | Answered on Jan 18, 2016
Could be power supply failure. It tries to start but can't.
Samsung LN... | Answered on May 16, 2015
flicking or shutting down,i have the same tv,mine shuts down,it needs power supply,yours needs the control board,get one on ebay
Samsung LN... | Answered on May 11, 2015
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should be troubles hooted. Contact any service technician. The circuit will differ with models and versions.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Samsung LN... | Answered on Mar 15, 2015
Page 64 of the user manual explains this procedure.
Go to Global Download Center and under Manuals, click See More + and then click on Download PDF.
Samsung LN... | Answered on Mar 03, 2015
Hi, not sure if you have the same fault as i had, but our tv only had half the screen go off, after looking up on the internet i found a video for a fix, what you need to do is remove the back cover, there will be ribbons that go from the front screen to the main panel, i removed each one at a time and rubbed the contacts of the ribbon with a rubber on the end of a pencil, plugged them all back in and switched it on and it was now spot on, thats more than a year ago and its still working spot on, hope this helps
jim
Samsung LN... | Answered on Mar 01, 2015
You can also replace the bad capacitors on the power supply board.
Samsung LN... | Answered on Jan 27, 2015
Sounds like the LCD Panel, if under warranty contact Samsung warranty for service. If out of warranty, watch it until you tire of it then replace the unit as the cost of a new panel is more than a new unit.
Samsung LN... | Answered on Jan 03, 2015
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center.If you wish to get some details; check the site linked here.Surf the site with patience.Pull up older posts.http://electronicshelponline.blogspot.com/ .In most cases, the main board might have to be replaced.If so, a software [firmware] update too might be necessary.
Samsung LN... | Answered on Sep 30, 2014
Fault with main board. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Samsung LN... | Answered on Aug 24, 2014
Samsung LN40C650 TV Logo
5 questions posted
Jerry Greenberg
Jerry Greenberg
Ekse
View Most Popular
LN Samsung
  • LN Samsung
Most Popular Question
samsung apps keeps running same update
  • Televison & Video
