20 Most Recent
Samsung UN40C5000 TV Questions & Answers
My Samsung UN40C5000 has a
Because you have the extended warranty, I'd say take advantage of it and call a technician out to assess the problem on-site - they can then advise you on the best possible course of action to take from there if required.
A third opinion by a service tech is valuable in matters such as this.
(it could be any one of a number of things which cause this kind of issue in flat panel sets; the service verdict at the end of the assessment determines the most logical outcome based on how serious the problem is)
Either way, you get to make the final decision; if you do choose to consult a tech, make doubly sure they are an authorized Samsung service agent and that they are willing to undertake the job under extended warranty.
I would not advise trying to fix this one yourself, especially if an extended warranty is current and valid on it.
12/23/2017 4:42:35 AM •
Samsung...
Answered
on Dec 23, 2017
Samsung led problems
What is the problem you faces with your TV? Provide more details please. If you wish to get more details, check
this link.
2/5/2013 9:12:08 AM •
Samsung...
Answered
on Feb 05, 2013
There is sound but no
solution
step 1 : at first test your fly back transformer
step 2 : A.C. transformer test or out put voltage measurement
step 3: test your video I.C.
Send report :
[email protected]
7/28/2011 9:20:20 AM •
Samsung...
Answered
on Jul 28, 2011
Can't get Samsung un40c5000 out
try this: Press the volume button on the T. When the on screen display come up, press and hold the MENU button for 5 seconds.
4/20/2011 12:39:24 PM •
Samsung...
Answered
on Apr 20, 2011
How to turn off display
Hi, try this :
1. Switch on your TV set
2. Open menu, choose
setup - plug and play
3. select language
4. enter pass code (0-0-0-0)
5. follow instruction until "
home use and store demo" appear.
6. Choose "
home use".
7. Follow the instruction agian untill plug and play setting finished.
3/18/2011 9:28:51 AM •
Samsung...
Answered
on Mar 18, 2011
Samsung 5 blink code
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
10/27/2017 12:21:54 PM •
Samsung UN...
Answered
on Oct 27, 2017
Samsung LCD TV UN55C7000WF will not turn on
Fault at its main digital board.
Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Led tv will not power on
Secret menu ? If you mean factory setup menu then might have to replace the digital main . When in that menu you have to be careful or its replace the board time !
