20 Most Recent Sony KDL46EX400 46 in. HD-Ready TV Questions & Answers
How can i repair a tv that turns on but has no picture or sound
Have you tried a factory reset? I had a similar problem my TV was stuck on standby (red light only) I did this
  1. Turn on the TV.
  2. Wait approximately 40 seconds for the TV to completely start up.
  3. On the TV remote control, press and hold the UP ARROW button
and it worked!
11/18/2015 10:55:59 AM • Sony KDL46EX400... • Answered on Nov 18, 2015
We unplugged our Sony KDL40XBR40 TV when we went away on vacation. When we came home and plugged it in the TV has no power lights, picture or video. Any suggestions?
Double check the outlet has power and the plug at the TV is fully seated in.
10/20/2015 2:48:32 AM • Sony KDL46EX400... • Answered on Oct 20, 2015
No sound or picture on sony lcd tv
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
10/7/2015 4:36:49 PM • Sony KDL46EX400... • Answered on Oct 07, 2015
Blinking red light 5 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
10/7/2015 4:36:09 PM • Sony KDL46EX400... • Answered on Oct 07, 2015
TV won't power on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy. http://electronicshelponline.blogspot.com/ Blinking codes details to many popular brand TVs are given. Surf the site with patience.
4/7/2014 4:47:07 PM • Sony KDL46EX400... • Answered on Apr 07, 2014
Can,t get a normal picture on screen all I get is
Hello, You will need to get into the tv's menu and change the "settings" area under display properties to read "normal" instead of "Zoom". Change that and you will be back to being able to see the entire display. Good Luck Rich Lilja
12/28/2013 3:42:36 AM • Sony KDL46EX400... • Answered on Dec 28, 2013
Price- Sony KD 46x400 in HD TV
try to browse on google..
6/25/2012 10:38:41 AM • Sony KDL46EX400... • Answered on Jun 25, 2012
KDL46EX400 stop working
what lights on front of set are on and or blinking?
4/28/2012 3:59:59 PM • Sony KDL46EX400... • Answered on Apr 28, 2012
Hi.I cant see any scores
If you're using an external cable box or the like, you'll need to tell it to output in 16:9 or 16:10 (widescreen). This should be found in the menus somewhere on your cable box. Probably under settings (surprise surprise). Once you've done that, with any luck you're TV should be able to adapt to the new widescreen video signal it's receiving.
Hope this helpes
Moza805
8/30/2011 5:11:18 PM • Sony KDL46EX400... • Answered on Aug 30, 2011
2answers
Sony kdl46ex400 turns on and goes off within 1 or
Good day!!!
normally,,that problem is caused of failing capacitors on the boards..
This is example picture of capacitor:
Follow this procedure on how to fix your TV..
  1. open the back cover
  2. look at the chassis/board inside your TV.
  3. try to look all capacitors inside..it likes the picture above..
  4. look at the actual image if it has a leak on oil/bulged on the top..
  5. try to replaced it with the same type,ratings and value.using soldering iron and soldering lead.
  6. after you replaced the bad capacitors..try to power it ON again to test if it is OK.
please watch this video for guide on how to replaced bad capacitors on the board.
7/17/2011 2:54:29 PM • Sony KDL46EX400... • Answered on Jul 17, 2011
The remote will not work
I would try this remote at the store on the same TV to see if it works there so you can figure out if the TV will need to be repair or they should give you a new remote, or the remote needs to be programmed.
Please leave rating if it helps.
1/13/2011 4:41:11 AM • Sony KDL46EX400... • Answered on Jan 13, 2011
During dark scenes or solid
It is under warranty, have it check before warranty runs out ASAP because you do not want to have something else goes wrong either.
12/19/2010 4:37:58 AM • Sony KDL46EX400... • Answered on Dec 19, 2010
The tv says no signal
It's kind of hard to answer your question with not knowing how your hooking up your TV. If you are hooking up a antenna or cable to your RF in you need to make sure you have your input set to TV and autoprogram your channels. If your using a cable box hooked to your RF in then you need make sure it is on and autoprogram your channels. If you are using a cable box, satellite receiver, or DVD player hooked up to your component, composite, or HDMI.input then you need to make sure you have you input set for that. Hope that helps.
11/29/2010 3:16:31 PM • Sony KDL46EX400... • Answered on Nov 29, 2010
Sony KDL46EX400 46 in. HD-Ready TV Logo
26 questions posted
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
KDL Sony
  • KDL Sony
Most Popular Question
no sound or picture sony lcd tv
  • Televison & Video
