20 Most Recent
Samsung PN50C550 50 in. TV Questions & Answers
IM LOOKING FOR A NEW SCREEN FOR MY SAMSUNG
You will find it hard to locate a part number for the screen if you by the Tv model number so you are better off opening it up and getting the screen model number from the back of the screen itself, Google that part number and Im sure you'll have no problem finding a replacement, the only thing I would say is the screens are probably about 60%-70% the price of a new tv so it may not be worth fixing. Best of luck either way.
Does PN50C550 unit work in
Where did u bought this tv?Like in a European,Asia,Middle East or African countries.Yes tv should work with PAL systems or format.If it was bought in the US,Canda or Mexico probally not it only work with only NTSC systems or format only.
Eu sou do Brazil. Desculpem
please
can you rephrase this question in English? I would love to help, but I
don't understand this language in which you are using to communicate.
I would appreciate it, if you can respond in English.
I look forward to your reply.
Bye for now.
Samsung plasma TV PN63A650 will not turn on, just makes continuous clicking.
the capacitors seem to have gone bad if they have like a black dot on them it is a sign they have actually blown they can be replaced by placing new ones on but it would be better if the board was replaced (unless you wish to replace those capacitors please please do be careful in doing so they hold enough charge to give you a bad zap even kill if one isnt careful)
Samsung 60 inch plasma not turning on. Unplug HDMI and turns on. Let it warm up (15min) then one HDI (720) works. Replaced caps but no change.
Fault at its main digital board.
Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here. ..
Samsung Plasma..clicking pn50a400c2dxza
Have you checked the sustain board/s. If you wish to get some details about how to check a plasma TV, visit the site linked here. It has details with illustrations. The shown is for an LG brand plasma, but all the plasma TVs will have same configuration and checking procedure, irrespective of its brand and screen size.
Pull up older posts. Surf the site with patience.
