20 Most Recent
Samsung LN46C530 TV Questions & Answers
Hi, My samsung ln46c530f1fxza has no picture only sound,I observe that the power light blinks about 4 times at start up.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "
Mosaic" or "
Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Do a search by type in the brand name of the device to the search box.
Samsung LN46C530 wont turn on.
Hey Mark,Samsung's are notorious for bad caps, have you ever opened up the set? There could be other problems but I would start with power supply capacitors. The tops should be flat, look for any that have bulging tops !!!
PLEASE HELP!
check the screen back light as will as the inveter board which have loose contact or dry joints.
We own a samsung flat
It sounds like you have the Store Demo Mode on. To turn this off, press the volume button. While the volume is displayed in the OSD (onscreen display), press and hold Menu for 5 seconds (or a bit longer).
Alternatively, you can find this in the menu. When TV is the source, press Menu > Setup > Plug & Play followed by Enter. (It's the second choice after Language.)
The manual is available here:
http://www.samsung.com/us/support/downloads/LN46C530F1FXZA . This is on page 7.
I hope this helps.
Samsung LN46C530 TV. Have had the TV around 1.5
G'Day
I have a similar Samsung set... and found that the remote sensor is rather low gain. I noticed the same thing when I first got the set. The remote did not seem to work. Pointing it directly at the right side corner at the power light of the set seemed to allow it to work. 10 degrees away from that either side and it does not work. I also had 2 remotes that behaved in a similar manner(got an additional free 22" set with my purchase). I also suggest changing the batteries out as the ones supplied with the set are generally low brand,and may not last that long.
Other than that, you may need to contact Samsung service to have the set replaced/repaired. Your best point of contact here is the retailer that sold you the set. If they cannot arrange for the repairs for you, let me know where in the world you are, and i will get a contact number for you.
regards
robotek
