20 Most Recent
Toshiba 55G300U TV Questions & Answers
NO picture but I do have sound on a 55G300U
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should be troubles hooted. Contact any service technician. The circuit will differ with models and versions.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Schemapic diagram for toshiba 55G300U
I see so many here with no sound/nopicture issues:ISSUES: 1. IF sound main fuse/s are good.2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.3. almost all these sets the troubleshooting involves
checking voltages on the main power board to narrow down theproblem.4. Be safe and if you do not know what you are doing don't open the set.Answers to issues:1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.3. Trouble shooting consists of the above and then at some point you have to buyand try a board to see if it fixes it or not.4. Safety first--no TV set is worth getting injured or even killed over.If set is opened at least look for puffed up and bad caps like in thisphoto.
No picture but I do
You might want to checked for bulged electrolytic caps on the power supply, that need changed or just replace the power supply module. Another thing that you can try, is to unplug the set from the wall for 40 Min, the video processor IC, could be locked up and that will reset it back to normal.
I have a 55 in
sounds like it is just a cracked solder joint on the power cord receptacle, as for repairs, as long as it is only a cracked solder joint there would be no parts required to repair it just a matter of opening up the set and re-soldering the joint. at most you would have to pay for probably a minimum service charge at a repair shop (if you are mechanically inclined and have done any soldering yourself it is a very easy repair to do yourself). Good luck and God Bless.
Toshiba 55g300u LCD, tried to upload firmware from
I havea Sony bravia, and was explicitly told if the power is off during update I shouldlook for a authorized service. It is too complicated to fix. But watchout, it might not be "under terms of guarantee". Don't know if this applies forToshiba, but just to let you know
Change batteries on my toshiba se-r0001 remote
- Locate the Battery Cover: Look for the battery cover on the back of the remote control. It is usually a small compartment that can be easily opened.
- Remove the Battery Cover: Depending on the design, there may be a latch, screw, or sliding mechanism to secure the battery cover. Use your fingers or a small screwdriver to open the compartment.
- Remove Old Batteries: Take out the old batteries from the battery compartment. Pay attention to the orientation of the batteries, so you know how to insert the new ones correctly.
- Check Battery Polarity: Take note of the positive (+) and negative (-) signs inside the battery compartment. Make sure to insert the new batteries with the correct polarity to match these markings.
- Insert New Batteries: Place the new batteries into the battery compartment, ensuring they are properly aligned with the correct polarity. Press them down gently to make sure they are secure.
- Replace Battery Cover: After inserting the new batteries, close the battery compartment cover securely. If it has a latch or screw, make sure it is fastened properly.
- Test the Remote: Point the remote at the device it controls (such as a Toshiba TV) and test whether it responds to your commands. If the remote is working correctly, you have successfully replaced the batteries.
- Dispose of Old Batteries: If the old batteries are no longer usable, make sure to dispose of them properly. Many communities have designated recycling locations for batteries.
3/9/2024 3:29:56 AM •
Toshiba...
Answered
on Mar 09, 2024
