20 Most Recent Samsung PN63C590 TV Questions & Answers
manual
PN63C590 TV Manual
Samsung PN63C590 TVUploaded on Apr 12, 2016
What size screws does a SAMSUNG TV PN 51E530 require for a stand mount
I just looked up the manual online and it clearly shows that the screw size is M4 x L12 metric screws
6/2/2022 7:28:11 PM • Samsung PN... • Answered on Jun 02, 2022
I have a Samsung PN50B530S3F plasma TV 2009. It has a black horizontal lines problem.
check the display strip. un plug it and fix it
5/14/2019 12:54:56 PM • Samsung PN... • Answered on May 14, 2019
Samsung plasma TV PN63A650 will not turn on, just makes continuous clicking.
the capacitors seem to have gone bad if they have like a black dot on them it is a sign they have actually blown they can be replaced by placing new ones on but it would be better if the board was replaced (unless you wish to replace those capacitors please please do be careful in doing so they hold enough charge to give you a bad zap even kill if one isnt careful)
1/5/2017 7:30:41 PM • Samsung PN... • Answered on Jan 05, 2017
Samsung 60 inch plasma not turning on. Unplug HDMI and turns on. Let it warm up (15min) then one HDI (720) works. Replaced caps but no change.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here. ..
6/30/2016 2:20:35 AM • Samsung PN... • Answered on Jun 30, 2016
2answers
Problems with video on samsung pn58c680g5f
www.samsung.com/us/support
2/1/2015 12:46:43 AM • Samsung PN... • Answered on Feb 01, 2015
My Samsung flat panael shuts itself off continuously
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
9/13/2014 11:12:41 AM • Samsung PN... • Answered on Sep 13, 2014
Samsung Plasma..clicking pn50a400c2dxza
Have you checked the sustain board/s. If you wish to get some details about how to check a plasma TV, visit the site linked here. It has details with illustrations. The shown is for an LG brand plasma, but all the plasma TVs will have same configuration and checking procedure, irrespective of its brand and screen size. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
8/27/2014 3:21:31 PM • Samsung PN... • Answered on Aug 27, 2014
2 year old plasma on 5 minutes no pic, but sound
yes take it to a tv tech would be your best bet. regards shaun
4/21/2014 4:30:08 AM • Samsung PN... • Answered on Apr 21, 2014
0answers
I have a 50" Samsung Plasma TV That has been working flawlessly, while outn of the room it powered down and will not turn back on. I Left it unplugged overnight, tried it again and it still will not
Check and replace the damaged component/s at its main power regulator board [SMPS]; or, replace this board as card basis. Contact any service technician. After replacement, the should be some voltage adjustments to be done to Plasma TVs. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. http://electronicshelponline.blogspot.com/ Pull up older posts there.
3/24/2014 12:48:13 PM • Samsung PN... • Answered on Mar 24, 2014
0answers
0answers
Samsung PN63C590 TV Logo
1 questions posted
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
View Most Popular
PN Samsung
  • PN Samsung
Most Popular Question
our plasma television narrow vertical
  • Televison & Video
