20 Most Recent
QSC GX5 2Channel Amplifier Questions & Answers
The channel 1 the light red is on
As always with stereo amps the two channels are identical, so if one goes wrong you have the other as a control for testing purposes. So if you start by looking and comparing the two channels. that's a start! If a part looks odd on the faulty channel, but is fine on the good channel you have found the problem. You can also do tests, such as touching the two channels with an insulated screwdriver, while powered up. If it buzzers on the good channel, it should buzz on the other channel at that point. Keep away from the power supply and ignore anything that is on it's own, that has no duplicate, or is common to both channels.
My QSC RMX2450 starts with red clip lights on. It turns to green only when there is input signal. Why is this
The red clip lights on the QSC RMX2450 indicate that the amplifier is receiving a signal that is too strong and could cause distortion or damage to the speakers. The green lights indicate that the signal is within a safe range. When there is no input signal, the amplifier defaults to the red clip lights as a precautionary measure. Once a signal is received and it is within the safe range, the lights turn green. This is a normal behavior for this amplifier.
2/14/2023 5:23:53 AM •
QSC Audio...
Answered
on Feb 14, 2023
