20 Most Recent Behringer EuroPower EP4000 2Channel Amplifier Questions & Answers
Want to connect more speakers
Use splitter cables to double your outputs. The signal strength will be half to each speaker per channel. i.e. if each channel has an output of 100w then splitter cables will give you 4 x 50w to connect up. Aim to use speakers rated below the max output rating of your amp, so in this example 4 x 40w speakers would be safer (won't blow your amp) than 4 x 60w speakers
2/18/2018 5:33:56 PM • Behringer... • Answered on Feb 18, 2018
The Amp clip light is always ON only the left channel and the same channel is not functioning by giving sound, please help
I looked at a schematic for EP2500 which is same but has a lower buss voltage than the EP4000. Below, the drive signal to the power stage is full wave rectified to illuminate the LED, d-c is presented to the LED if R128 & R138 has an a-c return. There is a line that can push-up the a-c return. It goes off to a connector that is unknown. I suspect the push-up voltage is not there. It could mean anything. I think its coming from the main transformer, Check for blow fuses. d9+gf5qhr0mzaaaaaelftksuqmcc Also the speaker output is protected with a "Crowbar" circuit. It is simply a Triac device (light dimmer) or two SCRs to prevent d-c from shorted output devices being applied to the speakers. which would cook the speaker coils. This may be activated when amp is turned on. Then there is the possibility of the output power devices - one or more shorted. h+pghp2gje82qaaaabjru5erkjggg== The amp needs to be checked out by a repair technician.
2/5/2016 11:54:07 PM • Behringer... • Answered on Feb 05, 2016
Every time i switch the amp on breaker comes out
If you have operated this amp normally before and it just started tripping the breaker and wont re-set, It will have to be checked by a technician to determine what is causing the overload ie shorted capacitor or some such.
12/22/2014 2:24:34 PM • Behringer... • Answered on Dec 22, 2014
Bias current behringer EP4000
What about the bias current? Most current amplifier, say within the last 15 years, do not have adjustable bias.
12/12/2014 11:28:19 PM • Behringer... • Answered on Dec 12, 2014
Channel 2 protection light on in ep 4000
Will be no doubt the main power amp that has failed that is connected to that channel. It will be located on a big heat sink and be hotter than the other(s) channels if you go in after it's been on.
1/3/2014 1:55:46 PM • Behringer... • Answered on Jan 03, 2014
0answers
Circuit diagram
Be the first to answer 12/2/2013 5:50:30 PM • Behringer... • Posted on Dec 02, 2013Be the first to answer
What part in the amp causes it to trip the breaker
which breaker at the back
8/12/2013 11:12:21 PM • Behringer... • Answered on Aug 12, 2013
I have a ep4000 amplifier, how can i connect to a
The rule of thumb is you control your audio on the low side. That means you plug your mics, tuners, audio sources into the pre-amp and then the pre-amp into the equalizer/mixer ant finally the mixer into the power amp and the amp into the "large honkin' speakers". The inter connects on the low side (between the source, the mixer and the power amp are usually done with RCA plugs. Use a good quality set of cables to get good tight connections and solid grounding.
AUDIO SOURCE?MIXER?POWER AMP---
heavy speaker wire sized to your SPEAKERS.
9/29/2011 7:27:41 PM • Behringer... • Answered on Sep 29, 2011
How do i connect a
Alwaays use balanced lines. The amp will accept either XLR or TRS at that end. The Numark accepts 1/4 TRS. You should probably get TRS to TRS cables... While these look a lot like "stereo" 1/4 inch cablles they are NOT. Thesee need to be intended for balanced interconnection. They will be twisted pair within a shield. Here is an example:
http://accessories.musiciansfriend.com/product/Monster-Cable-Studio-Link-500-Interconnect-TRS-M-TRS-M?sku=331684
4/26/2011 10:19:03 PM • Behringer... • Answered on Apr 26, 2011
0answers
What is causing my EP4000
You're amp is probably approaching thermal mode which causes the amp to overheat and eventually shut down or if it has a limiter built in this is due to distortion. You must lower your output volume.
10/5/2010 4:57:43 AM • Behringer... • Answered on Oct 05, 2010
Left input clips at all input levels and from
Hi.. It sounds like one of the power supply rails ( + or - ) is not functioning. These run around 80-100V DC It will need service
10/4/2010 11:01:29 PM • Behringer... • Answered on Oct 04, 2010
Behringer ha 8000 transformer replacement help.
Toroid Transformer is used in power supply not with headphones out. Headphones out are directly connected with headphone amplifier IC. (Note that the difference in 4700 and 8000 is number of channels. Rest of the circuit diagram is same). Behringer HA 4700 PowerPlay Pro-XL ' SynthXL - FREE Service Manual
12/19/2023 2:37:58 PM • Behringer Audio... • Answered on Dec 19, 2023
Behringer PMP3000 audio mixer: the effects are stuck on 90. Cannot select any other effect program.
When a heavy item is dropped onto the top of a control, it can break internally. I would check the encoder switch is working correctly, if not, replace if needed.
12/7/2023 7:40:55 AM • Behringer Audio... • Answered on Dec 07, 2023
My behringer pmp1680 has no output to speakers
Check the routing and toggle the buttons. It may be a tarnished connection.
10/8/2023 7:06:08 PM • Behringer Audio... • Answered on Oct 08, 2023
Please help! Behringer KX1200 master volume stops past 4 and no lines work just fx return
Also how do I reconnect the fan? It sounds like you may have a broken potentiometer (aka volume knob) for the master volume control. If that is the case, you would need to replace it with a new one (or take it to an electronics technician to diagnose and repair). Regarding the fan disconnection, this likely isn't causing your issue but you would still want to reconnect it as it keeps your amplifier cool while in use. Reconnecting is fairly straightforward - all fans have 2 or 3 wires that connect to corresponding terminals on the amp. Just make sure you don't mix up which wire is positive and negative, and make sure they are connected firmly and securely.
2/23/2023 12:47:59 PM • Behringer Audio... • Answered on Feb 23, 2023
No sound from mxl 990 condenser mic
I would order new cable price = quality. CBI cables with neutrik connectors.
2/7/2023 7:29:21 PM • Behringer Audio... • Answered on Feb 07, 2023
Behringer EP1500 amp does not produce full loudnes
Hi, Please test the loudness of your device with a third-party decibel meter. This will give you a clear measure of whether the loudness of your device is changing with increase in volume. It could be that your surroundings are absorbing the increased sound. Thank you.
10/11/2022 12:40:04 AM • Behringer Audio... • Answered on Oct 11, 2022
Behringer EuroPower EP4000 2Channel Amplifier Logo
19 questions posted
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Behringer Audio Players & Recorders
Most Popular Question
channel 2 protection light in ep 4000
  • Audio Players & Recorders
