20 Most Recent
Marantz 2230 Questions & Answers
One side not working
the 2230 is a fine unit! There could be several things causing this problem, more than likely it could be dirty front controls which will require cleaning. It could be more serious problems such as pre-amp or main amp failures, dried up output coupling cap for the right channel. I would recommend having the unit serviced. These older vintage Marantz units are really special and deserve proper attention.
Thanks
www.back2lifeelectronics.com
11/21/2016 5:44:11 AM •
Marantz 2230
Answered
on Nov 21, 2016
I need balance control pod
http://www.vintage-electronics.ccthese guys have older stereo parts...and they offer a repair service too
3/1/2012 4:36:26 PM •
Marantz 2230
Answered
on Mar 01, 2012
Marantz sr 2230 stereo receiver
do the basic test
-first connect the RCA cable into the auxiliary input power on the receiver
-connect the speakers to the speaker output of the receiver.
-set the volume into the maximum level
-touch the RCA cable input with your hand you should hear a loud humming sound when you touch the RCA plug.
-if no sound is heard the reciever is defective or you had connected it to the wrong terminal check your connection..
9/14/2011 9:55:39 PM •
Marantz 2230
Answered
on Sep 14, 2011
Either chanell cuts out randomly. It is not over heating
Intermittent problems are no fun to troubleshoot because you have to force it to fail or wait
for it to show the problem. It sounds
like it could be a thermal problem or a cold solder connection. Do you
hear the sound through the headphone
jack on the receiver when the speakers blank out? If so your pre amp section is
working, and it is in the power amp section. If not I would first use a spray contact
cleaner on the switches and rheostats. Click on the link below for Cleaner.
http://www.mcmelectronics.com/product/200-150
Second, wait until the
unit exhibits the problem then use a freeze spray selectively spraying parts of
the board and components until the sound returns. You can use a heat gun
sparingly to heat parts of the circuit to try to force it to fail. If you selectively
freeze spray the board and sound returns you need to inspect the board for
broken traces and touch up solder connections, which could be cold and faulty.
If you spray a component and the sound is restored it could be a bad component,
and it should be inspected. Click on the link below for freeze spray.
http://electronics.mcmelectronics.com/search?af=&w=freeze+spray
7/21/2010 3:48:41 PM •
Marantz 2230
Answered
on Jul 21, 2010
Marantz CD5004 tray keeps opening problem
CD/DVD players use a protocol;
Open tray. Insert disk. Tray switch tells mechacon that the tray is shut. Attempt to focus on disk.
If focus is acheived, then it will spin up and try to read the disk otherwise it will ask for a readable disk.
If the tray keeps opening, I would suspect the tray detect switch is malfunctioning, maybe the drive belt has stretched.
HI, would you know what error code CY920 on my Marantz NR1607 means ?
The Marantz NR1607 is an AV Receiver, and the CY920 error code is not a recognized error code for this product. It's possible that this is a custom or specific error code for your device, and I would recommend contacting Marantz support or the manufacturer for more information. They may be able to provide you with a solution or more information on what the error code specifically means and how to resolve it.
The poweramp of my Marantz SR6004 AV Surrount Receiver only turns on after about 3 minutes.
Parece que el problema puede estar relacionado con la fuente de alimentaci?n de su dispositivo. Es posible que desee verificar si la fuente de alimentaci?n proporciona el voltaje y el amperaje correctos. Adem?s, es posible que desee verificar si hay conexiones sueltas que puedan estar causando una interrupci?n en la fuente de alimentaci?n. Tambi?n puede intentar restablecer el dispositivo a su configuraci?n de f?brica para ver si eso resuelve el problema. Si estas sugerencias no funcionan, es posible que deba consultar el manual para obtener pasos de soluci?n de problemas m?s detallados o ponerse en contacto con un t?cnico calificado para obtener ayuda.
Marantz DV 9500 DOES NOT PLAY ANY of normal CDs. Reads ONLY Super Audio CDs. What could be the cause for this fault?
- Hardware issue: The CD player may have a hardware issue, such as a damaged laser or faulty electronics, that is preventing it from reading normal CDs.
- Firmware issue: The CD player's firmware, which is the software that controls the device, may be outdated or corrupt, causing it to only read Super Audio CDs.
- Compatibility issue: The CD player may not be compatible with normal CDs, and is only able to read Super Audio CDs due to their specialized format.
In terms of adjusting the laser pick-up, it is generally not recommended to try to adjust the laser pick-up yourself, as it can be a delicate process that requires specialized equipment and knowledge. If you believe the issue may be related to the laser pick-up or other hardware, it may be necessary to seek the assistance of a qualified technician or the manufacturer.
If the CD player is unable to read the content of a normal CD and is returning to 00:00 tracks on the display, it is possible that the issue may be related to the laser pick-up or other hardware. It is also possible that the issue may be related to internal ICs or other electronics, in which case it may be necessary to diagnose the issue further to determine the cause and find a solution.
Marantz sr18 sound goes out
NOT A CAR/TRUCK SO MOVED TO AVR
THE AVG. AVR HAS OVERLOAD DETECTOR AND LAMP AND RELAY
THAT FAILS WHEN OVERLOADED.
PER THIS SIMPLE LIST
- SPEAKER WIRES SHORTED.ENDTO END
- SPEAKER SHORTED.
- TOO MANY SPEAKERS WIRED IN PARALLEL.(THE ohms rule violated)]
- the amps side is failing.
- the overload detector is bad, telling lies, and shutting it down.
- try no speakers, to see if it trips.
- It is 1999 and is old. even bad caps inside now.
only does
Digital inputs: coaxial, optical
Video Connections: component, composite, SVHS
the rig has fan sensor failure and over temp too, and the service manual covers that.
see protector DRIVE here, it shuts down all outputs via relays.
free to read and DL.
https://www.manualslib.com/manual/1066247/Marantz-Sr-18-U.html?page=6#manual
