20 Most Recent
LG Kp107 Cell Phone Questions & Answers
My LG KP107b mobile is
The security code is usually the last four digits of your cell number, or four zeros. I hope this helps!
I want lg kp107b unlock
Hi, there is no free unlock code in this world my friend even if you requested from your original network provider, they still takes a charge from you up to $80 for a straight of unlock code. The only way to get
LG KP107b unlock code is buying from third party sites with lower cost rather than pay some charge from your provider. There is many online store and third party sites that sell
lg unlock code.
I forget the security code i get the code
ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
My lg kp107b phone was
Use your puk code to
unlock lg kp107b security code. Puk code can you get from your sim card bundle or asking from your network provider. If this solution can't
unlock lg phone security code you can reflash your phone at nearest mobile repair store.
I am trying to unlock
I don't know where you get
LG KP107 unlock code, since if you have that
lg unlock code usually you have the details instruction how you enter it even you get that code from provider they always send unlock code with details instruction. I think you buy that code from unknown source and I doubt you have correct unlock code since you don't have details instruction from them.
Insert sim
Possible fault in the mother board and it is best to check this out with a service center if you had done a reset by removing the battery and then replacing.
Take estimate and decide.
My lg model is KP107b.....
The barring password must be provided by the service provider. Barrings are a network issue and the service provider will give you the default password.
I deleted my important phone
hello,since you have deleted your phone numbers,so sorry about that,but there are no ways to restore it back,except you backed them up on your system,
take care...
I have a LG KP107b
Why the phone goes off when you connect the charger is because the connection was not straight up, so it will turn off the phone and it will go blank. When it does that, you just have to remove it, turn off the phone and remove the battery and insert it back in, then you fix in the charger before connecting it to the power outlet.
TIP: Always attach the charger into the phone first before you connect it to the power socket or outlet. That way it will never trip off when you attach it to the charger.
Thank you for using fixya
Caseytech
Hi I have an LG
yes sure you can.be sure to install first the software application of your cellphone to your computer to be able to navigate the cellphone system.
