20 Most Recent
LG BL20 Cell Phone Questions & Answers
RECOVER DELETED PHOTOS
First thing to note is that the deleted data on the phone will remain there until something new is saved and overwrites it. This might not happen immediately but eventually, after continued use, it will.Either connect the phone straight to a PC using a USB cable (if supplied with the phone) or take the card out and put it in a card reader attached to the PC. You should see memory card shown as a drive letter (like H:) in Windows Explorer.Then try some
pic recovery software on the PC. This should recognise the phone or card and then you can scan it using the free download of some good photo recovery software. That will show you what files still exist on the phone or card and what can be recovered.
http://www.asoftech.com/articles/mobile-phone-data-recovery.html
Display
you need a new screen as the lighting element has burnt out you can grab these at any market stall be prepared to haggle with the price and all you will need is either t5 or t6 torque screwdriver to undo all the screws if still under warranty take it back to the shop and they will repair for free
SIM Inisiliging showing tuch centre
If you meant SIM not detected and contact service: then please do accordingly after checking the SIM contacts to clean and set it in.
If not contact LG service.
When I turn off my
when you do change the language you have to save this operation .then it will be saved even if you turn it off and re turn it on
PUK mymobil do not know.Where
To get PUK code please contact your service provider.they will provide you the defaultPUK so that you can open your phone.
While you get the PUK code ,the serviceprovider customer care officer will askfor your personal details to checkwhether the mobile belongs to you only.If they are satisfied with your answers they will providewith the PUK code
Note: if you keep entering random/unknown numbers/codes, the sim card will be lockedand will be rejected. It'll not beusable anymore.
If you need further help, let me know.
Good Luck.
Thanks for using FixYa.
PUK's mymobil do not know.Where
Hi, your PUK code can be given only by your service provider which is specific for each and every mobile number. Contact your sim customer care department over phone. It's free of cost to get the pin or puk no. If you can't contact through your phone get some other phone and contact them, or go to the nearest service outlet of your service provider they can also help you.
PUK code is also on your SIM card documentation Starter Pack. If you do not have this then -Please contact your phone service provider................
Lg fb163-how to add bluetoth function
To add Bluetooth functionality to your LG FB163, you can use a Bluetooth adapter that is compatible with the device. Ensure that the adapter you choose is compatible with the FB163 model. Once you have the adapter, follow the instructions provided with it to connect it to your FB163 system.
To connect your Android phone to the FB163, you'll need a compatible cable. Typically, you would use an auxiliary (AUX) cable with a 3.5mm jack on both ends. Plug one end into the headphone jack of your Android phone and the other end into the AUX input port on the FB163 system. Then, select the AUX input mode on the FB163 to hear the audio from your phone through system.
