20 Most Recent
Whirlpool WFW9150W Front Load Washer Questions & Answers
Wont drain
Hi.
If the machine does not drain the parts that can be responsible are the drain
system and pressure switch. Motor and control board must also be tested if the first two are Ok. If machine is a
top loader testing will start from lid switch. a first action will
consist in checking the drain hose at the back and checking the drain
filter accessible from lower front side of your Whirlpool.
Here a page about drain and spin problems.
If you need parts or schematics see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
9/14/2011 1:37:20 PM •
Whirlpool...
Answered
on Sep 14, 2011
Whirlpool model #WFW9150W front load
If it sounds like a freight train in spin cycle most likely it is your bearings. If it makes a clunking noise during the wash cycle you have a broken support. The best way to tell is to spin the basket by hand and listen for the noise. Check to see if the basket is making circles and not ovals. Pull back the rubber seal and look signs of the basket rubbing against the outer plastic tubs. If is either one of these it is cheaper to buy a new washer than to fix it. Fixing it involves rebuilding the machine. If it only makes the noise when it starts to drain you need to check your pump for foreign objects.
7/13/2011 12:01:38 AM •
Whirlpool...
Answered
on Jul 13, 2011
