20 Most Recent 2004 GMC Sierra - 2500 HD, 4WD, automatic, with 9200 GVW - Complete Lift Kit Questions & Answers
Did you do any work to the A/C System like try and put Refrigerant in the System or change a hose . There is a switch that is located inline of the system that sometimes can stick before pressure build up or on the other hand pressure to low will make the A/C compressor cycle on and off . This works the power to the A/C Clutch which tells the Compressor to turn on as needed which you should hear clicking on and off when your hood is open. First of all if you found that you needed to add Refrigerant then you must have a leak because this is a closed system and their should be no reason to add Refrigerant unless you lost Refrigerant . Do you have a set of Manifold gauges or are you using a auto parts store recharge kit . The most common problem people have is the a/c compressor not running of shutting off to soon and not cooling the car down and the most common reason is a Leak , To Much Refrigerant , To Less Refrigerant , To much Peg oil added to the System , the Evaporator Pressure Operated Electric Switch and of course A/C Compressor Belts slipping and many other issues related to trying to do it yourself .In your case you said the pressure of Refrigerant was high so I assume you have a gauge of some sort . You under law are not allowed to just release into the Air the Refrigerant so if you have to much have it drawn out and put the correct amount in . If you get the pressure down you might find that the system starts running properly . If you still have an issue you can follow the steps I list to make the proper test to see what is going on . warm up the engine and set the A/C to the coldest setting and put the blower on highest setting next open the doors and keep them open so the A/C system does not cycle off as you look under the hood to see the Compressor and see if you can see the compressor clutch engaged the clutch makes a click and the center of the clutch will rotate . If it is clicking then you see the clutch stop then you may need Refrigerant or the system might be over charged . this is where having a gauge would be good . Now if the compressor s engaged and stays that way close your doors then see if the Clutch starts to cycle if so the system is fine if you have nice cool air coming out of your vents . The A/C is not going to keep the Clutch engaged at all times only as need by the temp control setting and temp inside the car . This is your starting point if you can't find the issue get back to me and we will take the next step. Good Luck .
2004 GMC Sierra... | Answered on Jun 11, 2014
same as jupiter all good
Vehicle Parts &... | Answered on Nov 08, 2019
Don't click on spammer Victoria Archer, as FIXYA doesn't remove most spammers automatically. Volunteers answer questions without charge.
https://www.scorpionauto.com/car-remote-alarm-immobiliser-scorpion-sa30/
Contact information.
https://www.scorpionauto.com/contact/
Vehicle Parts &... | Answered on Oct 25, 2019
Tip
Longer lasting engine maintenance
Your engine will last a lot longer as far as the main engine components if you 1)change your engine oil at vehicle recommended mfg intervals.TIP: if you live in hot climates you should change your oil more often and at less miles .2500 to 3000 ml. every 3 months because the climate the hot temperatures break down oil viscosity at a higher rate thus needed more frequent oil changes for the best engine engine lasting performance.2) always use the recommended weight example (5/30w)TIP: Also for best results the recommended rating of the oil for example on the back of the oil bottle is a rating 2 or 3 letters in a circle .Older vehicles use a different rating than newer vehicles and some times they are not interchangeable this information should be available at your local parts store.3)TIP;: Always use the recommended (brand) oil filter.With the way cars are now especially ones with overhead cams and chains ,aftermarket filters might not supply the same pressure aspects of the original oil filter, So as far to have less or more pressure than that is needed to maintain these components correctly with the correct pressure.
Thanks hope this helps
on Oct 22, 2019 | Vehicle Parts & Accessories
check compression
Vehicle Parts &... | Answered on Oct 14, 2019
if you lost all compression on all cylinders at the same time check your timing belt or timing chain. good luck .
Vehicle Parts &... | Answered on Oct 09, 2019
It is suitable for a number of vehicles, as it includes long bays for vans, and short bays for other vehicles, and with minimal alterations it is suitable for installation in any vehicle model.
It offers more storage capacity for odd sized items, and represents easy inventory control, by reducing the need for overstocking expensive items in your work vehicle.
The system is fully adjustable.
Vertical adjustments can be made to gain maximum use of your vehicle height, while horizontal adjustments can follow the contour of your van, to allow for more aisle space.
The rak-a-van system provides maximum working space and fast access to all items, and optimises productivity.
Tradesman Fitouts 4WD Sydney
Vehicle Parts &... | Answered on Sep 26, 2019
Vehicle Accessories is the leading discount store for automobile accessories. We offers you various cars and bike accessories such as tyre and wheel, replacement parts, auto spare parts , vehicle exterior and interior care services from the best brands at the most affordable rates. The company offers a wide selection of car products, including auto electronics, cleaning materials, oils and fluids.
Vehicle Accessories is an online store that offers all the latest in car parts and accessories at reasonable prices. You can find everything you need to customize your car to make it truly your own.
This Vehicle accessories shop online sells everything under the sun to deck out your car in the best way that fits your needs. If you're getting ready for the summer, you can find all the essentials like waterproof seat protectors, connectors and cables to connect your kayak or surfboard to your car, and bike racks so that you can get out and enjoy the fresh air.
Vehicle Accessories has several locations in Australia where you can buy accessories and products for your car in addition to a full range of services to keep it running at top performance.
Car Accessories Sydney
Looking for the best vehicle accessories installers from Melbourne Contact Local Mechanics Melbourne for better results.Local Mechanics are one of the premier auto repairer groups bringing together customers and their local mechanics across Australia. All mechanical services are performed by highly qualified and licensed mechanics.
Most likely the receiver antenna is defect.
Try see if it is there and is connected correctly.
Off course you have checked the transmitter battery is full!
Vehicle Parts &... | Answered on Sep 25, 2019
get some super lube. pull the cover all the way out and lube the mechinsum
Vehicle Parts &... | Answered on Sep 20, 2019
hi ,i need a pin code to nats...
vin :SJNBFAP11U0594153
NISSAN PRIMERA 2001 1.6
Please Help..
Vehicle Parts &... | Answered on Sep 15, 2019
should be on the tail of tranny left side
Vehicle Parts &... | Answered on Aug 16, 2019
You need to register with snooper to download the updates(even if previous owner has done so) or else you can ask him his user id and password
Vehicle Parts &... | Answered on Aug 14, 2019
You can use this for most of it. Most remote starts/keyless entry/alarm do the same things. Most are even colored the same way.
https://www.manualslib.com/manual/460639/Directed-Electronics-Autocommand-25523t.html
Vehicle Parts &... | Answered on Jul 11, 2019
Why you need a wrap? The new ones are wrapped mainly cos people don't like the company color and they want their ride to be unique. I believe it's the same for you. Vehicle wraps are better option; cheaper compared to repainting; easy to remove when you think you changing it.
Vehicle Parts &... | Answered on Jul 09, 2019
I would check your crankshaft sensor , also your fuel filter to make sure it is clear
Vehicle Parts &... | Answered on Jul 05, 2019
On most cars, you have to find any hidden screws in the armrests and remove those. Then if you have electric windows/door locks lift up around the base of them with a flat head screwdriver to get them to pop out and be able to unplug them. When that is done, you usually can just lift at the bottom of the door panel and you will unpop the plastic inserts as you work around the door.
2004 GMC Sierra - 2500 HD, 4WD, automatic, with 9200 GVW - Complete Lift Kit Logo
1 questions posted
Top Rancho Vehicle Parts & Accessories Experts
Murad Miro
Murad Miro
Level 1 Expert
Richard Warren
Richard Warren
Anthony Pettenger
Are you a Rancho Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Rancho Vehicle Parts & Accessories
Most Popular Question
c not cooling checked freon pressure
  • Vehicle Parts & Accessories
