20 Most Recent
PLANMECA PM 2002 EC Dental X-Ray Questions & Answers
How do I correct error #64
Ooooh, error 64 is not easy. If it was 63 you'd be ok or even 65....not so bad but 64 is a tough one. You may need to re-shuffle the discombobulataory co-functional interpolations by accessing the ancillary positioning extrapolation cog that rotates the comfufulator prior to the sequential disengagement of the photomagraphical fusion vacillator After that it's pretty straightforward apart from the reverse thrust inductors needing a shunt to blow the cobwebs out. If that doesn't work, you could try cutting the power supply off, throwing a dust sheet over it and using it as a hat-stand. Good luck
What do they mean by low heart rate?
The normal heart rate is really an average heart rate, around 80 beats per minute. Many things can make it go faster or slower, including activity, medication, drugs, exposure to insectisides or mushrooms and others. A slow heart rate is called bradycardia, usually around 60 beats per minute. Sometimes the electrical nodes in the heart which help to make the heart start a new beat quit or work incorectly. In these cases medication or a pacemaker are required. I hope this answers your question.
10/18/2021 4:22:56 AM •
Medical
Answered
on Oct 18, 2021
Five steps for brush your teeth perfectly
Aim the toothbrush at a forty five degree attitude towards the gum line.
Use a pea-sized quantity of toothpaste.
Use a gentle round motion.
Repeat on the interior surfaces.
Use a mild backward and forward motion at the chewing surfaces.
Spit out the toothpaste after brushing.
You do not need to rinse, as the small quantity of fluoridated toothpaste left to your mouth after spitting maintains to defend in opposition to enamel decay.
