20 Most Recent Waring MBB518 2Speed Blender Questions & Answers
Does anyone have a schematic showing how to put the motor back together. mine was taken apart, and now I can't find the washers and need to replace and put everything back together correctly. any he
follow this steps . God bless you
  1. Unplug the blender and remove the jar. Undo the screws securing the baseplate. Separate the baseplate and attached motor collar from the base housing.
  2. To remove the switch housing, remove the decorative facing to get at the top screws. Remove the lower screws from inside the blender base.
  3. Hold the fan to keep the motor shaft from turning as you unscrew the drive stud. Remove the shield and any washers. Unscrew the fan nut to remove the fan.
  4. Disengage the strain-relief fitting from the housing. Remove the wire connector joining the power cord and the lead to the brush housing.
  5. Label and disconnect the lead wires from the switch block. Remove the motor mounting bolts and lift out the motor if necessary.
  6. To free brushes, remove the leads attached to the brush housing. Use a screwdriver to press lead terminal through the slot in housing. The brush spring may pop out (don't lose it!).
11/24/2013 12:44:40 PM • Waring MBB518... • Answered on Nov 24, 2013
Need picture waring mbb518 blender motor
Go to the following link and locate your blender's model type: http://www.waringcommercialproducts.com/product-documents.php?type=parts
11/24/2013 4:12:10 AM • Waring MBB518... • Answered on Nov 24, 2013
0answers
I'm looking for a replacement blade for a waring VP 1000, can anybody help?
https://www.ereplacementparts.com/part-type/blades/blender/waring
1/15/2023 5:10:56 PM • Waring Blenders • Answered on Jan 15, 2023
To take the Waring blender apart to replace the power cord, but no screws are visible to unscrew it from the casing?
remove the rubber feet pads and discover the screws
2/9/2021 3:35:00 PM • Waring Blenders • Answered on Feb 09, 2021
Remove motor from 1940s F-2 Waring blender
If you think you need to replace it, first make sure you can get the part. then look for a parts breakdown at an online parts store. If that doesn't help you will have to hunt and peck to figure it out. Do not be too aggressive, though after all these years things will be stuck.
9/14/2019 10:17:43 PM • Waring Blenders • Answered on Sep 14, 2019
I have an older Waring blender, model WF1112218. My problem is I took it apart to clean it and now can't figure out how it goes back together. Is it rubber gasket then rotor or the other way around?
Hello, Carla -For all electric blenders the rubber gasket is placed between the glass or plastic blender container and the rotor with the blades.The assembly is easy to recall when one realizes the rubber gasket is the seal for keeping liquids leaking out of the blender.See the image here (it's for a Black and Decker, but the assembly is the same):http://stainless-steel.us/12-pictures-of-baby-bullet-blender-instructions/black-and-decker-blender-assembly-instructions/The image here shows the assembly for a Waring blender (different model than yours):https://www.etundra.com/restaurant-parts/parts-diagrams/waring-bb140-bb150-bb240-bb250-bar-blender-parts/Best wishes.
6/2/2018 12:15:22 AM • Waring Blenders • Answered on Jun 02, 2018
I have a Waring Pro HPB300 that doesn't seem to be connecting to the blade to make it blend and this creates a burning smell.
Dear Katie, If your machine has a belt inside, it is probably bad. However, most do not. I am suspecting you have a bad bearing inside the machine, and the burning smell is wires; in the which case, please do not use this machine again until it is repaired, so you do not experience a fire. God bless your efforts,.
5/25/2018 7:24:54 PM • Waring Blenders • Answered on May 25, 2018
How to replace waring blender 028538 drive coupling
Check and see if your blender was made in China. If so, the chances are really slim for a finding parts for a fix. If it was made in the USA, try "e-bay" for parts. If you need a parts list, you will need to find one first. Also, type Waring Blender into your search engine on your computer, to see if a dealer or repair place has a web-site. God bless your efforts.
1/9/2017 7:26:18 PM • Waring Blenders • Answered on Jan 09, 2017
Leaks at the bottom of the glass holder
I'm no expert but in my experience if it leaking at the bottom then either the jar /carafe has a few chips or cracks around the hole in the bottom that the blade fits through and in that case you need to replace the jar and your blade assembly may still be good and can be moved to a new jar/carafe. Or the blade assembly has come loose a little and need to be tightened or some the washers (usually the rubber ones) have worn out and need to be replaced. There's plenty of explanation here at amazon and else where on how to replace the assembly blade, move it to a new jar and tighten it down, etc. Hope this helps!
9/12/2016 2:44:26 AM • Waring Blenders • Answered on Sep 12, 2016
Waring MBB518 2Speed Blender Logo
Popular Tags
10 questions posted
Top Waring Blenders Experts
Mike Cairns
Mike Cairns
ADMIN Eric
ADMIN Eric
vince
Are you a Waring Blender Expert? Answer questions, earn points and help others
View Most Popular
Waring Blenders
  • Waring Blenders
Most Popular Question
anyone schematic showing put motor back
  • Blenders
