20 Most Recent La Pavoni CUA001R Cuadra Espresso Machine Questions & Answers
When pulling coffee by opening
in the system you have 2 safety valves. one for tank other for coffee boiler. the coffee boiler safety valve should be set at 12 bar. if safety valve of boiler is leaking try resetting or changing rubber than setting.
ps: do not touch the tank safety valve, only change it with new, tested and sealed one.
2/12/2011 2:35:35 PM • La Pavoni... • Answered on Feb 12, 2011
Light does not go on and no power in my La Pavoni ECL 12.
hi try another socket if still do not work you probably used it without water and heating element thermostat above the boiler has to be reset regards GUy
11/12/2021 7:47:43 PM • La Pavoni Coffee... • Answered on Nov 12, 2021
A leak between the boiler and the delivery unit
hi if you can tight the bolts on side of the group heade that might help if not you have top replace the o ring regards Guy
7/8/2019 9:04:57 AM • La Pavoni Coffee... • Answered on Jul 08, 2019
Pavoni piston can't go high enough to let water into the chamber
hi you probably have your piston rod is little bit loose from piston so it does not raise piston high enough so group head must be disassemble and reconnect the rod with loctite regards Guy
7/8/2019 9:03:29 AM • La Pavoni Coffee... • Answered on Jul 08, 2019
Light does not go on and no power in my La Pavoni ECL 12. Has been working perfectly up until now.
Thank you so much
Just reset mine !
6/22/2019 6:35:25 PM • La Pavoni Coffee... • Answered on Jun 22, 2019
La pavoni slow water flow
Try running some white vinegar through it as if you was making coffee (but don't use any coffee) and when done either repeat processes or run a clean pot of water to clean out the vinegar and see if the water is coming out faster. You might need to repeat process a few times. The vinegar breaks down any hard water residue.
2/5/2017 2:55:54 AM • La Pavoni Coffee... • Answered on Feb 05, 2017
I'm looking the right part (portafilter or handle and cups) for my La Pavoni Duet PA-1315.
try this link if not listed use contact us or ask some parts may have been discontinued La Pavoni Parts
10/12/2016 1:03:28 AM • La Pavoni Coffee... • Answered on Oct 12, 2016
What causes my la pavoni europicola to make a whistling when it;s turned on?
hi it is normal when water heating up and pressure begin to be built in the boiler until the vacuum braker at the safety valve close but if it continue to whistle when the green light goes off after few minutes it means you have too much pressure in the boiler and it is realesed through the safety valve in that case you have to replace your pressurestat or you have scale at the bottom of boiler in the entrance of the pipe leading to the pressurestat regards Guy
4/2/2016 6:52:59 PM • La Pavoni Coffee... • Answered on Apr 02, 2016
Coil sealant
HI you shouldn't use sealant. if the silicon seals are broken they should be replace, they are available from sellers on ebay.
1/3/2015 1:39:29 AM • La Pavoni Coffee... • Answered on Jan 03, 2015
Hi what size tamper do i need for la pavoni ebr machine about 12 yrs old thanks
Hi I have one of these in the attic, they do not come with a tamper as they have a fancy pressurised portafilter , its good to level the coffee and if I remember I did used to give it a bit of a tamp as it just didn't seem right not to. I have found a couple of references to tamper size on the web and both say 53mm I can't totally vouch for this though, you can always check with a ruler.
12/16/2014 9:51:44 AM • La Pavoni Coffee... • Answered on Dec 16, 2014
Where can I find a user manual for la pavoni ubar V3
Hi I have had a search using the info you have given but I can't find a reference to a UBAR I have put a link to pavonis site which leads to the specifications for some of their BAR products. Their website is a bit unhelpful but if you search on their site for PDF you may be able to find what you need. I used a add on for firefox that searches within the site you on for any word you have in the search box rather that looking on the whole web. from this you might be able to work out the model you have. http://www.lapavoni.com/PDF/CAT_BAR.pdf
12/16/2014 9:37:34 AM • La Pavoni Coffee... • Answered on Dec 16, 2014
La Pavoni CUA001R Cuadra Espresso Machine Logo
Popular Tags
1 questions posted
Top La Pavoni Coffee Makers & Espresso Machines Experts
Sulejman Sulejmani
Sulejman Sulejmani
NOEL
NOEL
Ngoro
Are you a La Pavoni Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
La Pavoni Coffee Makers & Espresso...
  • La Pavoni Coffee Makers & Espresso...
Most Popular Question
when pulling coffee opening
  • Coffee Makers & Espresso Machines
