20 Most Recent
Magimix 4100 Cuisine Systeme 1268 Cups Food Processor Questions & Answers
New magimix won't start
It is most likely the way the bowl and lid are set.Facing the machine: the bowl locks in, with the handle to your right directly above the switches. The lid has a double tab...see underside of the top of the lid. Place the lid on tightly with both tabs locked into bowls handle. It really clicks in.
Unable to use magimix cuisine system 4100 given to
Get in touch with www.magimix-spares.co.uk
This is a family owned firm which specialise in everything for Magimix.
BBS Ltd.,
Unit B
Grovebell Industrial Estate
Wrecclesham Road
Farnham, Surrey
GU10 4PL
England
Hi my magimix 320xl won’t turn on the Handel clicks in ok so I’m not sure what the problem is it’s only been used a couple of times hope you can help me thank you Christine
If your Magimix food processor won't turn on despite the handle clicking in, there may be a problem with the power supply or the motor of the device. Here are a few troubleshooting steps you can try:
- Check that the power cord is securely plugged into an outlet and the processor's base.
- Make sure the outlet is working by plugging in another device.
- If the outlet is fine, then try plugging the Magimix into a different outlet.
- If the device still doesn't turn on, it's possible that the motor has overheated. Allow the device to cool down for a few hours and try turning it on again.
- If none of these steps work, you may need to contact the manufacturer or a repair technician for further assistance.
It's also worth noting that the Magimix 3200XL comes with a 30-year motor guarantee, so if the motor is the problem and the device is still under warranty, you may be eligible for a replacement.
How do I remove the blade unit from Magimix cuisine 5100?
Firstly, press the STOP button. Then turn the lid in a clockwise direction and lift-off. Carefully remove the blade and inner bowl/bowls (depending on what combination you are using). Finally turn the main bowl clockwise to unlock it from the motor unit and lift off.
