20 Most Recent Samsung SMH8165STE Microwave Oven Questions & Answers
Unless there is grease, moisture, or some other foreign material deposits on your control circuit board, "SE" means you have a shorted membrane keypad.
For the official repair information as per the Samsung bulletin, see http://www.microwavecontrol.com/samsung_se_error.htm
See my profile picture if you need more help.
We're
happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Samsung... | Answered on May 23, 2016
Try calling Samsung....
Purchased samsung SMH8165ST in Oct 2009. have had the SE code problem for a few month now. Resetting worked at first. Then the light started flasing on & off along with the beeping...would not reset. Out of frustration I called Samsung. I was told they are aware of the problem & would repair in the "epidemic warranty". Repair man just left. It took him about 15 minutes to change out the keypad. No charge!!
Samsung... | Answered on Jan 02, 2014
You have blown a fuse. Check inside the oven chamber and look for missing powder paint or signs of arcing, if so there is a paint to repair microwaves for this issue or else just dispose of the microwave. If the inside is good remove all the screws and remove the cover. Replace the fuse. If the magnetron was making louder noises prior then replace the magnetron. Since the fuse went the giant capacitor is likely bad. While the cabinet is open make sure to look for burned wires, check the continuity of thermal cutoffs, and check the main circuit-board for burned traces or components. The relays in most electronics are known for arcing (spot welding) and staying in the wrong position. Tap them hard with the back end of a screwdriver. During all of this use safe electrical practices by having the power cord unplugged. The capacitor could still have a high charge on it so be careful.
Samsung... | Answered on Dec 05, 2013
make this test and fix it. GOD BLESS YOU
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
Samsung... | Answered on Nov 01, 2013
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
https://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Samsung... | Answered on Sep 27, 2013
What is wrong with it when it has the SE code?
Samsung... | Answered on Jul 07, 2013
see this step and fix it. God bless you
SE or 5E codes are usually sensor problems. it is also a catch-all for a keypad shorting issue. if it's either issue then it will need professional service. to test the sensors:
SENSOR TEST (QUICK TEST)
1. With 2 fingers touch and hold the following pads at the same time :
pause and cancel
2. Observe diagnostic number in display (Numbers approximate)
ex) 33 (Vs) 39 (Vout)
? Vout Vaule : 10~150 (Normal-verify with "detection test" )
? Over 150 or Less than 10 (Sensor failed. Check connection of Sensor.)
Samsung... | Answered on Oct 16, 2012
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
heatman101 ;';
Samsung... | Answered on Aug 07, 2012
Samsung SMH8165STE Microwave Oven Logo
50 questions posted
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Gerry Harvey
Gerry Harvey
Ekse
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Microwave Ovens
Most Popular Question
samsung household
  • Microwave Ovens
