20 Most Recent
Dualit 40352 4Slice Toaster Questions & Answers
Dualit toaster sticking timer
This a common problem for all dualit toasters after some years since the timer is also a power electric contactor and the cotntact are sticking. Their is not any solution and you need to replace the timer with new one. You can buy a new one from ebay which the prices are very good and we have also one
link how to reach the elements which will help you reach also the timer.
My 4 slice dual it keeps popping the breaker
One of the heating element is broken and the heating wire which have live electricity is touching the body of the toaster and thus the poppong of the breaker. So you can use this
link and check which is the broken heating element . You can buy one or more heating element from ebay there are only two kinds CENTER and END which you have choose from, they will aslo supply aslo replaceing instructions.
How do you replace a broken heatng filament
You can buy new heating elements from ebay. They are only two kinds one for the CENTER and one for the END. They have also the instructions for replacing them and we ha also a usufull
link that can help you
I have a 4 slice
Hello, happyI was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about toasters andpossibly yours, from repair to trouble shooting it. http://home.howstuffworks.com/how-to-repair-small-appliances1.htmPlease if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.Thanks, Mikehttp://beta.fixya.com/users/mc1bean
Trps the breaker as soon as switched on
Check the wire for any cuts, burns or kinks. You may have a short in the wire or inside the toaster (two wires are touching or arcing causing the breaker to trip).
Hi. my wife bought a
All you need is to match the voltage and frequencies. So you need to check if the toaster is 220'240V and 50hz. If not it is better to sale it back on ebay and buy the same model with above voltage. In order to make it compatible you will need a transformer and the cost for the transformers is depends on the watt and for 2000W it will cost 120-140 $
Where can I find the
We believe the best option is from ebay, Dont worry the distance they ship the elements in and envelope since they are thin and light so even uk is not costly and arrive fast.
Hello, the timer on my toaster keeps sticking.
This one of the most frequent problem of dualit toaster. Timer is also power electric switch whith contacts which from long time use they stuck due to sparking during contact. You need to replace the timer switch . you can find one at ebay is the same for all models. just take care the voltage 120v or 240 v. Als take a picture before remove the wires on the timer since you might forget how to put them back on the new switch.
The timer control knob keeps sticking, what is
This one of the most frequent problem of dualit toaster. Almost all have to be replaced after 5-8 years of use.Timer is also power electric switch whith contacts which from long time use they stuck due to sparking during contact. You need to replace the timer switch . you can find one at ebay is the same for all models. just take care the voltage 120v or 240 v. Als take a picture before remove the wires on the timer since you might forget how to put them back on the new switch.
Toaster wont heat up
The dial on the toaster keeps getting stuck.
The timer has started to
Timer switch needed
you can find one at ebay just take notice of 120V or 240 V the timer is the same for all models
