20 Most Recent
Kenmore 1667 Mechanical Sewing Machine Questions & Answers
Kenmore model # 11607090 older
as for the hand wheel not not being able to turn, it's possible that something could be loose or broken
you said it's been sitting for several years,, I would suggest that the machine needs to be serviced
by a sewing machine repair shop, where they can check the handwheel & find out why it won't unlock, & that the gears & inside the machine can be checked & grease & oiled & the timing check also
Missing manual
RE: Kenmore Jaguar Quick System sewing machine, model # 158.1070180
I have this machine and the manual. I even still have the receipt from
when I bought it in April 1990. It just stopped working this year. I
might hold on to it and get it repaired one day. Handy little machine, I
took it everywhere with me. Is there someplace I could send you a
scanned copy if you're still looking for it?
Tina
How do you adjust the feed dog height on a Kenmore 1690 (158.16900) sewing machine?
To adjust the feed dog height on a Kenmore 1690 (158.16900) sewing machine, you can follow these steps:
- Turn off the sewing machine and unplug it from the power source for safety.
- Remove the needle and presser foot from the machine.
- Locate the feed dog adjustment screw, which is usually located on the backside of the sewing machine, near the feed dogs.
- Use a screwdriver to loosen the feed dog adjustment screw. It might be a slotted screw or a thumbscrew, depending on the model.
- Gradually adjust the height of the feed dogs by turning the adjustment screw clockwise or counterclockwise. Clockwise rotation raises the feed dogs, while counterclockwise rotation lowers them. Make small adjustments and test with a scrap fabric after each turn to achieve the desired height.
- Once you have set the feed dog height, tighten the adjustment screw securely.
- Reinstall the needle and presser foot, and plug in the sewing machine.
- Test the machine with a piece of fabric to ensure the feed dogs are working properly and at the desired height.
It is important to consult the sewing machine manual for specific instructions related to your model, as the location of the adjustment screw may vary.
How do I find the manual for a model c970 555624
You can try to find the manual for your Kenmore model c970 555624 by following these steps:
- Visit the Kenmore website at www.kenmore.com.
- Click on "Customer Care" at the bottom of the page.
- Click on "Manuals & Guides" in the "Quick Links" section.
- Enter "c970 555624" in the search bar and click "Search."
- If the manual is available, it should appear in the search results. Click on the manual to view or download it.
If the manual is not available on the Kenmore website, you may need to contact Kenmore customer service directly to request a copy.
