20 Most Recent
Euro-Pro 801B Sewing Machine Questions & Answers
I need cord and pedal for 801
try these sites for the parts
sewingpartsonline.com
sewvacdoctor.com
whitesewingcenter.com
sewingpartsdirect.com
sewingsupplywarehouse.com
sewforless.com
Need cord and pedal for euro pro 801
sewvacdoctor.com
sewforless.com
brubakersewing.com
The needle is threaded top and bottom but when I
Recheck the threading on the top side. When you pull the thread at the needle is there tension on it? If there is no resistance than there's no tension. If it breaks it is either not threaded correctly or the tension is way too tight.
If that is correct and the the thread on the bottom has a little bit of tension when you pull on it, it should stitch --- However not stitching at all can be from having the wrong needle, wrong brand, type, or in incorrectly. Sometimes even the wrong size can prevent stitching, like when youre sewing through heavy/thick material and using too small a needle.
Check out those three things and then see if it won't sew correctly for you.
I have an EURO-PRO sewing machine model # 6130. I
You can oil all moving pieces that you can see, use a stainless oil for sewing machines. If you want to take your bottom off you can oil and grease the gears under there.
But I caution you to have a sewing machine repair shop do it for you, problems can be created if you oil and lube the wrong things.
Please rate my solution
I need a user manual
here are some websites to see if they have a manual
mastersewusa.com
sew4less.com
sewingmachinestitch.com
sewingcenter.us
europro.sewingmachine1.us
I'm looking for the service Manual for an Omega Euro-Pro Serger. Model number 434D.
You can try contacting Euro-Pro directly to see if they have a service manual available for the Omega Euro-Pro Serger model 434D. Alternatively, you can try searching for the manual online through a search engine or online manual database. There are also online forums and communities dedicated to sewing and serging that may have resources or advice on how to troubleshoot or repair your machine.
