20 Most Recent
Husqvarna Scandinavia 100 Sewing Machine Questions & Answers
My husqvarna viking classica 100 is sewing
The best way is to take it to an authorized repairman.You can try getting it very warm, like putting it in the warmest sunlit room in the house, or in the back seat of the car in sunlight. If it works better when it gets warm, the reverse mechanism will need to be cleaned. Then you can take it to an authorized repairmain.
3/8/2017 4:33:24 PM •
Husqvarna...
Answered
on Mar 08, 2017
I was given a husqvarna sewing machine.The only #
You might start with contacting Husqvarna's Customer Service.
Their USA contact info is:
SVP Worldwide
C/O Husqvarna Viking
P.O. Box 7017
LaVergne, TN 37086-7017
Toll free assistance - 1-800-446-2333
Monday-Friday 8:00 am - 4:00 pm CST
Email:
[email protected] (Please allow 72 hours for response)
Best of luck!
2/24/2016 8:41:47 AM •
Husqvarna...
Answered
on Feb 24, 2016
Manual free download
Give www.Manualslip.com a try. I download mine manual as a PDF forms and print it out myself.
3/9/2015 7:52:39 PM •
Husqvarna...
Answered
on Mar 09, 2015
I change light bulb in husqvarna classica 100?
if you don't have the accessory that looks like a short piece of rubber hose used to remove and reinstall the bulb, take the machine to an authorized Viking repair dealer and ask them to install a new bulb.
2/9/2015 3:56:56 AM •
Husqvarna...
Answered
on Feb 09, 2015
Change the presses foot
Check the user manual. You can view, download, or print the manual free from the viking website -
http://www.manuals.husqvarnaviking.com
See page 11.
Changing the Presser Foot
! Turn off the main switch
- Make sure that the needle is in the highest position. Pull the presser foot towards you and slight pressure downwards.
- Line up the cross pin on the foot between the spring and the presser foot ankle. Press back until the foot snaps into place
10/16/2014 3:07:13 AM •
Husqvarna...
Answered
on Oct 16, 2014
Pressure foot pressure control
The pressure foot knob had some problems. on this model. The solution was to remove the covers and the e clip that holds the knob in place. I install a belleville spring washer on the knobs shaft. This extra tension keeps the knob from turning when the sewing machine vibrates. This may be more difficult than most consumers want to attempt.
10/13/2013 5:25:29 AM •
Husqvarna...
Answered
on Oct 13, 2013
Oiling 100 model
Most machines need periodic lubrication (oil, grease, or both) and typically the external covers will have to be removed to get at the parts that need the lubrication.
2/12/2013 9:07:37 PM •
Husqvarna...
Answered
on Feb 12, 2013
Ive lost my power cord
Do a web search and you should find what you need either through E-bay or a parts supplier. Example - type in: "scandinavia 100" "power cord"
1/31/2013 9:40:15 PM •
Husqvarna...
Answered
on Jan 31, 2013
Our machine will not reverse
Does you machine go in reverse and just not sew in reverse? If this is the case you might have a feed timing problem. Clarify your exact situation.
4/27/2011 6:59:30 AM •
Husqvarna...
Answered
on Apr 27, 2011
I have a Scandinavia that
You may use the upholstery thread in the needle, but not the bobbin. Use standard size thread in the bobbin. If you absolutely need to use the upholstery thread in the bobbin, you will need to adjust the upper and possibly lower tension in order for it to work.
2/26/2011 11:10:38 PM •
Husqvarna...
Answered
on Feb 26, 2011
